Is it ok to mount 37s on a ford ranger
max07
Forum Member
mn
It’s a 98 ford ranger plan on sas after the torsion bar suspension breakes could I mount 37s or would the suspension break right away
What kind of 37s?
They will take it for general use...but if you weld the front diff and wheel the wee out of it....it will be labor intensive.
A quality Toyo AT on 16 or 17,s will have higher joint maintenance...and unit bearing life.
It will be stronger on stock geometry and cut fenders and a body lift...
A 4in lift depending on setup can be troublesome.
If it's already geared to 488 you may get by fine
What kind of 37s?
Well it’s stock lift fenders are getting cut or took off stock everything it
What kind of 37s?
Fender just cut or took off no lift just stock ranger most like going to sas
