- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Tire Size
- 35x12.50R15
Y'all are waaaayy overthinking this and confusing a (single) progressive-rate coil spring with the two individual springs you'd put onto a coilover to create a progressive rate coilover (the math you're trying to apply here applies to the ratings of two separate springs to find the overall rating for them together).
Rubydist is correct. On a single spring like you have here that is made from one length of wire, the lower spring rate figure is for the entire length of the coil spring (385PPI is what you have before the upper coil windings make contact with each other). When the coils do make contact, the spring then becomes 650PPI.
So 1100lbs @ 385PPI would be 2.857" compression.
18.625 (free length) - 2.857 = 15.768" (compressed length).
15.768" - 10.5" (stock compressed height) = 5.268" (the amount of lift height)
What we still don't have here though (and is what rubydist was attempting to get at initially) is at what point in the amount of spring compression does the spring rate change from 385PPI to 650PPI? If that happens before 2.857" of compression is reached, then the 5.268" lift figure goes right out the window. Hopefully this does not occur before 2.857" because that would actually defeat the purpose of having a progressive coil since you'd then be riding on the 650PPI section most of the time.
On the lever thing, Hound is on the right track. It has to do with the way the beam pivots off the frame, and the fact the coil spring is at a mid-point along the beam (a solid axle does not function as a lever, the entire thing moves as one, the coil springs compress at the same speed the suspension moves, so no leverage ratio applies).
Years ago I had made a diagram to help explain this, but for some odd reason it's disappeared off my computer, and interestingly it seems to have vanished from the 'net as well (it was an overhead-view diagram of the TTB w/radius arms with red lines to show the TTB pivot axis, and separate green & blue lines to show the difference in lever length from the pivot axis to the tire contact patch, and from the pivot axis to the coil spring. The line leading to the tire was approx 1.5× longer than the line to the coil spring.
If you need, I can try to recreate the diagram, though my printer/scanner has been a little temperamental lately (the original base image I used was from my '94 FSM).
Edit
Geez, this thread is moving quick lol
Floored's numbers about match mine, and again we're trying to guess where the transition from soft to stiff occurs.
Progressive rate springs IMO are a headache, and really offer nothing to boot. If you need more resistance to the suspension bottoming out in whoops and dips, it's better to achieve that through shock valving/bypass shocks, perhaps combined with hydro bumps. Progressive springs do work better on the rear though where you might be carrying different weight loads (leaf springs having an overload leaf are progressive rate).
Edit
