bobbywalter
TRS Technical Staff
Ugly Truck of Month
TRS 25th Anniversary
- Aug 9, 2007
- woodhaven mi
- Total Lift
- sawzall?
- Tire Size
- 33-44
- My credo
- it is easier to fix and understand than "her"
If you assume that the entire 1100 lbs is applied at the 385 rate, then the deflection is 2.85" and the compressed length is 15.77" - BUT you are guessing that it is all at the lower rate since you don't know everything you need to know. So, you get over 5" of lift at the spring. (note that if part of that 1100 lbs is at the higher spring rate, then the compressed length of the spring is even longer resulting in more lift.)
its not the 385....its 250 ish...they move together.
the point of the variable/progressive rate coil is the softer ride of the 250 over the 385 and 650.
i am unclear of what the goal was. because this only applies to a 90 degree s/a as to what would actually happen. not the case with sla or ttb. for sure ball park.
there is no fixed stop with a single multirate coil over like you have with a coilover setup...
it just depends on what you do with the truck. i use my truck as a truck and overload the fawk out of it. the rate of sag you get from the progressives was cutting into my time and tire life so running a single rate with air bags inside worked perfect. super soft for crawling and high rate for hiway cruise....better than a sway bar.
