How to: Fix intermittent charging from alternators with separate stator wire
BRUTUS_T_HOG
ASE Certified Tech
Rainier, OR
Original Poster: BRUTUS_T_HOG
Difficulty: 1 out of 10
Time to install: 5 Minutes
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
Brief Explanation:
Ford vehicles with this alternator style commonly experience intermittent or no charging due to a corroded or loose fitting stator wire, most often found when the alternator starts to charge after wiggling the stator wire. This fix only applies if you are having this problem.
Tools Needed:
Needle nose pliers
Small flat screwdriver
Pick
Parts Needed:
Di-electric grease
Make sure the ignition key is OFF
Steps 1: Remove the stator wire by gently prying the plastic tab and pulling the plug.
If the connector is corroded clean it by scratching it up with a pick. DO NOT spread the terminal of the connector more than it already is, that is what caused the trouble in the first place.
Steps 2:
Take the needle nose pliers and put a gentle and very slight twist on the pin sticking out of the alternator.
Put a dab of Di-electric grease in the connector and plug it back in.
Done!
