- Aug 6, 2007
- Age
- 41
- Moore, OK
To answer the first question, YES, I do run with Royal Purple oils. I've been doing so since 90k miles, and still @ 110k miles. I also do get an oil analysis and results come back good. RP is API approved for street use. The racing blends I do believe are not. The difference between GL-4 & GL-5 is for different metel compands. Use GL-4 for soft metals in transmissions. In diffs, it depends on the l/s. RP gear oil can be used for both GL-4 & GL-5 spefic transmission. Or use the SyncroMax when the transmission requires a motor oil, straight grade, or atf.
Is there benefits? Somewhat, but it is hard to adjust for the cost per quart. I use it mainly because everything that has ran on, runs better now.
Leave MAKG alone, he has his reasons. And I trust his advice to an extent.
My oil intervals.
Oil: 5k
Trans: 25k
Diff: 50k
My oil intervals.
Oil: 5k
Trans: 25k
Diff: 50k
shady
