GPS Speedometer
Featured Build Threads
85_Ranger4x4
Wallers in rivers
💻 TRS Socials
Frankfort
IA- USA
5.0L
Has anyone on here used one?
Do they really need the antenna outside the vehicle? (preferably on the roof)
I really don't want the antenna on the roof... and if I have to have one I think my slide in camper will block it anyway. I really don't want it on the dash either...
I had a thought last night, my Garmin GPS doesn't need an antenna to read the vehicle speed, and even with the handheld under the dash on the transmission hump (for testing) still reads the trucks speed accurately.
I've been wondering the same things. My phone and tablet seem to do fine inside the cab.
I think it may be a case of deciding what you believe is "acceptable error. On a big flat roof with unobscured line of sight to the sky, logically seems best. But if it is "accurate enough" when sitting on the center console inside or on the transmission hump, then, why bother with a fancier mounting location?
I'm going to have the OEM VSS signal going to my digital dash. So I have a good speed signal. But I will probably connect the gps antenna and display that speed also, for comparison. I'm considering mounting the antenna on a small steel plate on the dash, or directly on the flat strip of cowling right in front of the windshield outside. The nice thing is that with magnetic mounting, it is relatively easy to experiment with different locations.
I got one of these. It plugs into a USB and projects on the windshield HUD style. I use it in my Nissan because the speedo needle has fallen off too many times to count. It's dead on accurate with my phones GPS, as far as MPH goes. It's real simple to use. Plug it in and go. It does take longer to "connect" sometimes, but we're talking 10 seconds, not minutes or anything.
I have something similar to Ranger850 in the F-100 because I can't trust the speedometer in it to work consistently. It sits on the dash, no external antenna, and it has been accurate with everything I have checked it against. Other vehicles, standalone GPS, phone, and those roadside speed camera signs.
Convinced enough that when I eventually install a Dakota digital dash, it'll use GPS for speed. Same for anything I put aftermarket gauges in.
I've noticed maybe about 5-10% of the time the GPS on my dashcam will fail to pick up any GPS signal for like 10 minutes or longer, occasionally not even before getting to my destination over a half-hour later (cam is mounted on windshield behind mirror).
Not sure if this is the cam itself, something with the GPS signals, or if a dedicated GPS speedo would have the same issue, but in such a case a GPS speedo would also read completely blank (I think I'd rather have a hard-wired / hard-cabled speedo myself, at least to fall back on).
Event Coverage
Featured Ranger Based Vehicle
