- Aug 18, 2007
1991
- Automatic
I have a Ford 7.5" 410 rear axle, ABS tone ring open carrier.
1996 Supercab, 3.0L automatic.
I was attempting a axle seal repair today, now I'm stuck.
I have loosened the ford 7.5" 410 pinion shaft lock bolt.
It is long.
I can slide it out till it hits the bearing carrier cap.
At this point one end is still in the carrier, so it won't come out fully.
I can remove the bearing carrier cap and get it out.
Is that standard operating procedure or a quirk of the 410 carrier.
Next problem is harder.
With the pinion shaft lock bolt pulled out as far as it can go
I can get the pinion shaft to slide down but
The ends of the pinion shaft are D shaped.
The center where the spider gears roll is round.
The round part hits the inside edge of the ring gear and it won't come out.
Do I need to unbolt the ring gear and slide it to the right to get the pinion shaft out?
Picture in a few minutes..
and
It is long.
and
