Exhaust leak from EGR tube threads
Featured Build Threads
tinoracha
Forum Member
California
Hi all, I've got a 1992 Ranger with the 2.3 and after doing some IQ tests recently noticed a significant drop in score. Come to find out I'm my exhaust is leaking in two spots.
I have replaced the exhaust manifold and it's continuing to leak from where the EGR tube meets the exhaust manifold. I've read that this doesn't need to be particularly tight so I started it at wrist tight and I've tightened this bolt a few times and seen no improvement, its quite tight at this point and has a healthy amount of anti-seize on it. It seems like the EGR tube and thread adapter are pretty hard to find and were never available from a third party manufacturer as far as I can tell.
Also the weld at the front of the muffler is leaking too, this muffler was installed about 4 years ago and my putty patch job has done nothing to improve.
I am not sure what the best course of action is now. Should I track down a new EGR tube and thread adapter from a pick-n-pull? Should I get the muffler welded? Thanks for any and all input!
Here's a video of the leaks with some soap on and the blower hooked up to the exhaust tip:
I have seen people use JB weld with good results on the exhaust. Not sure if it would hold way up at the EGR but I would try it. It would certainly hold on the muffler if you could get all the old stuff you put on there off. That will be a problem also if you get it welded. He can't get a proper weld with a bunch of contaminants in the area of the weld. That goes for JB weld also, so you will have to make the decision which way to go.
Event Coverage
Featured Ranger Based Vehicle
