EPA vs CARB
Nothing wrong with a universal cat - disadvantage is there may be some welding & fabrication involved as it's not a bolt in direct fit item (usually.) The direct fit will bolt right in but it'll be more expensive.
I don't know if a performance cat would be worth it. Maybe if it's stainless steel. I have the factory cat in my '82 F250 that still flows but we've all seen late model vehicles with plugged up cats - just depends on the situation.
Well I like the universal option since I have the luxury of a realistically priced install. There's a "high-mileage" magnaflow, says more metals but still ceramic coated. I really just want longevity. It's on amazon (yikes) but it's through the magnaflow store and is sold/shipped by amazon which is usually better.
California
Air
Resources
Board
Anything certified to work with CARB is "cleaner" and more expensive. Not "better", just more expensive. I would go with the federal/EPA part.
Shran is right. The CARB cat has more expensive precious metals in it to make the exhaust cleaner. If you don't need it or don't have emissions testing, the EPA cat will be just as durable.
Just make sure you just replace the cats only. I used a Walker complete kit with their Y-pipe. It did not fit very well, and the pipe gauge was thinner. I had them replaced several times under warranty because the pipe kept cracking. I eventually had the pipe reinforced where it was breaking and replaced the manifold flange area with thicker pipe and have had no problem since.
I never had a problem with the cats. I wish I would have kept the original pipes and had just the cats replaced.
That's what I'm going to do. However, since I'm putting in a new engine, I'm going to wait til after break in. I've got a local shop that can cut and weld a new cat for $75-100. So that frees up the budget to get the most durability per dollar I can find.
Yeah, the CA model probably just has more volume of substrate, won't necessarily last longer...
The biggest problem that kills cats is msifires, the unburnt air fuel mixture ignites in the exhaust that is already like 400C, once it hits the 900C range the ceramic turns to liquid pretty quick...
So the amount of the rare metals doesn't affect longevity? What does it do then? Does it improve processing?
It's not the metals that does everything, it's a combination of everything... there's the surface area and length that changes the "space velocity" I think is the technical term, basically the hang time the exhaust has in contact with the metals that work on a chemical reaction based on oxygen storage to work on the chemical reaction to make more favorable compounds like CO2 and H2O instead of CO and oxides of nitrogen (they all get lumped into NOx). The different metals do different things on the reactions, it's complicated and I don't remember what does what, we only use one "loading" at work.
Thank you. Yeah, chemistry is not something I'll ever claim to understand. I really just want the best $ to time ratio. Like I said before, I'm pretty blessed to have a local shop for exhaust that is very well priced and honest and good.
