EPA vs CARB
Featured Build Threads
Nothing wrong with a universal cat - disadvantage is there may be some welding & fabrication involved as it's not a bolt in direct fit item (usually.) The direct fit will bolt right in but it'll be more expensive.
I don't know if a performance cat would be worth it. Maybe if it's stainless steel. I have the factory cat in my '82 F250 that still flows but we've all seen late model vehicles with plugged up cats - just depends on the situation.
Well I like the universal option since I have the luxury of a realistically priced install. There's a "high-mileage" magnaflow, says more metals but still ceramic coated. I really just want longevity. It's on amazon (yikes) but it's through the magnaflow store and is sold/shipped by amazon which is usually better.
California
Air
Resources
Board
Anything certified to work with CARB is "cleaner" and more expensive. Not "better", just more expensive. I would go with the federal/EPA part.
Shran is right. The CARB cat has more expensive precious metals in it to make the exhaust cleaner. If you don't need it or don't have emissions testing, the EPA cat will be just as durable.
Just make sure you just replace the cats only. I used a Walker complete kit with their Y-pipe. It did not fit very well, and the pipe gauge was thinner. I had them replaced several times under warranty because the pipe kept cracking. I eventually had the pipe reinforced where it was breaking and replaced the manifold flange area with thicker pipe and have had no problem since.
I never had a problem with the cats. I wish I would have kept the original pipes and had just the cats replaced.
That's what I'm going to do. However, since I'm putting in a new engine, I'm going to wait til after break in. I've got a local shop that can cut and weld a new cat for $75-100. So that frees up the budget to get the most durability per dollar I can find.
Yeah, the CA model probably just has more volume of substrate, won't necessarily last longer...
The biggest problem that kills cats is msifires, the unburnt air fuel mixture ignites in the exhaust that is already like 400C, once it hits the 900C range the ceramic turns to liquid pretty quick...
So the amount of the rare metals doesn't affect longevity? What does it do then? Does it improve processing?
It's not the metals that does everything, it's a combination of everything... there's the surface area and length that changes the "space velocity" I think is the technical term, basically the hang time the exhaust has in contact with the metals that work on a chemical reaction based on oxygen storage to work on the chemical reaction to make more favorable compounds like CO2 and H2O instead of CO and oxides of nitrogen (they all get lumped into NOx). The different metals do different things on the reactions, it's complicated and I don't remember what does what, we only use one "loading" at work.
Thank you. Yeah, chemistry is not something I'll ever claim to understand. I really just want the best $ to time ratio. Like I said before, I'm pretty blessed to have a local shop for exhaust that is very well priced and honest and good.
Anymore, shops like that are like finding a gold mine. Locally, there are only two places I trust to work on my vehicles, if I can't do it myself. Partly because of the quality of work, and the prices they charge, but also their attitude. Given that people like us venture out of the box of what is considered normal, a good number of places treat people like us like we are some kind of idiot. As soon as they do that, I take my business somewhere else regardless of how reasonably priced they may be.
i dare not to take my truck some place to have it worked on.
it would be.... hmmmm. like taking a jhon deere and massy conglomeration into a ford dealership...
You only need CARB certified if you live in California, which you don't.
As long as the engine is running properly, any aftermarket cat should last at least 100,000 miles.
I put a universal aftermarket cat on the Jeep Wrangler my daughter use to have. It had been replaced once already and the welding looked like it was done by Moe, Larry, and Curly. Also the exhaust manifold was cracked so I got a Banks header and exhaust along with the cat. It ran fine and passed emissions every year for the next 5 years she owned it. We have annual emissions inspections where I live.
Are you trying to pass a smog test? If so, do like I did when I lived there, before I moved my official residence to a non bi annual smog check zip code to stop dealing with that BS.
Buy a new cheap universal aftermarket cat, just for smog checks. Put it on before driving to the test and take it off afterwards and replace it with any old cat you have. The cheap cats work fine for a little while, then lose their performance. I'd rather buy 2 cheap cats than one special California cat. The feds don't care, as long as there's a cat in place. Same thing with oxygen sensors.
Fresh oil change, new plugs and tune up, and depending on your engine health, maybe some better fuel. Certain types of fuels and additives help the engine run cleaner. Make sure your cooling system is in good condition, as heat raises Nox levels. Early morning or cool months are better for smog tests because of the dyno and the fans they use don't flow the same amount of air as driving down the road.
I couldn't imagine still living in states that require auto inspections.
I pulled the OBD2 on the sensors, it's 100% shot. Sensor 2 was jumping up and down.
Im not an expert, but I’m pretty sure that’s how narrow band O2 sensors read, just constantly switching between 0v and .99v. Only reading ,450V briefly when they hit their calibrated O2 ratio.
o2 sensors do wear out though, so if they’ve got more then 100k on them they should probably be changed anyway.
That’s not correct. Multiple states have adopted CARB standards, including Pennsylvania. Any car sold in PA needs to be CARB compliant.
Just because the state inspection process can’t tell the the difference between a CARB cat and a Federal cat doesn’t make a it legal.
That's pretty much how narrow band sensors work but since the catalyst uses up the stored oxygen in the chemical reaction the post cat sensor reading is WAY more filtered and will usually float around the 300mV to 700mV range and the diagnostics will count the switches pre and post to try to make sure the post cat isn't switching at the same frequency as the pre cat.
Event Coverage
Featured Ranger Based Vehicle
