- Jul 20, 2009
- Age
- 38
- Ontario, Canada
- Automatic
Alright so wired the alt differently this wknd as stated by sparyk2eh had mentioned for a 3wire gm alt. Soo i now have the power straight to batt positive, jumperd from terminal #2 to alt power and terminal #1 going to green with red stripe oem cable. (batt indicator light). I have a charge of 13.3v on the batt when engine is running so pretty sure the internal regulator is working. Im gunna wire terminal#2 straight to the batt positive next wknd bc i think the voltage drop is causing it to be 13v and not 14.
Ok but i still have a draw from the battery when its not running! Also when running by batt indicator light is on in the cab but alt is charging.. Does this come on if its below 14v and rewiring the terminal #2 will fix it or is it bc i just spliced into the oem wiring. I went to the green w red stripe wire and it goes through the oem connector through the indicator and to the oem regulator, is that right? Should i be putting that wire directly from alt to batt light indictor an bypass the ranger regulator altogether?
And any other thoughts on the draw? Cant obtain a ammeter for dc so if i cant get this sorted by next wknd think im gunna have to take it to ze shop..
Thanks again to everyone for the imput.
