- Jan 16, 2023
- Birmingham, AL
- 3.0 V6
- Automatic
- Total Lift
- 4"
- Total Drop
- 0"
- My credo
- Speed Limit 70 (Chevy, Just Do Your Best)
I really hope someone speaks DTC and can translate to English. This one all started when I rolled my window down. Had been working fine.
Rolled it down and up a couple of times while removing and installing the engine, replacing the dash cluster, and rebuilding the steering column.
Took her out for the first drive after the rebuilt engine, and rolled the window down. Went to roll it up, and it wouldnt move. Fiddled with the switch after I gave it a few minutes and got it up. Now it won't roll down. Diagnostic tablet gave two codes.
B1398 - Left front power window relay circuit malfunction
B1302 - Accessory delay relay circuit malfunction
Googled them and it seems they are likely related problems. Normally for this issue, I would just install a new master power window switch. But I don't know what the accessory delay relay is. Does anyone know where I should start?
The only other ETC was:
P1000 - On board diagnostics II monitor/drive cycle test not complete.
If I understand this one, it just means I need to drive it for a while until the self test completes. Doesn't seem to be a point to worry about.
Thanks for any help.
