YungICY
- Jul 19, 2013
I need some help with a rear disc conversion I did on my truck.
Truck is an 85 using factory manual master cylinder, wilwood proportioning valve mounted next to the master cylinder, new hardline from master cylinder to rear to new soft line to a ruffstuff disc conversion caliper.
The rear brakes are dragging bad. If I crack open the bleeders after driving I get a little spurt of fluid under pressure. Lowering the pressure via the proportioning valve seems to help but doesn’t alleviate the issue. Sitting in my driveway in neutral I can’t roll the truck
Is there a residual valve built into these masters for the original drums?
