"DISC BRAKE" Pedal Pad Fitment for 2nd Gen. Ranger
SCOTTY
Above the equator
I would be very surprised.
I'm going to @bobbywalter this one...
Yes...
but may require :icon_welder:
:derisive:
Due to the way they install, a tight slip on fit, if it is wider across the top I wouldn't expect it to just fit. I doubt it would take much work to modify the pedal so that it would fit though. Make a plate that is proper size for it to snugly fit onto then weld or bolt that to the existing prake pedal.
If that's the look you like, go for it. If you're after is as some sort of performance improvement (IE larger surface or more grippy) I think you could find better options in the universal stuff on flebay.
Easy…. Cut the part you step on off your pedal and a donor pedal assembly…. Weld donor pedal plate onto your original. Install rubber pedal pad.
yeah...what sno said....and....i like it. maybe i should get one....mine is worn right out.....almost to a nub
Thanks for chiming in guys !
I don't really want to put a lot of work into it & finding a donor plate would be hard around here.
For now I contacted Auto Krafters & hopefully they will send me the 3 measurements I asked for.
I'll post them if they send 'em to me.
1 seller on ebay refused due to needing to remove it from packaging.
Thanks for the input !
