Completely Out of Options...
MikeGuevara
I have a 1998 Ford Ranger V6 3.0L Manual, and about 2 weeks ago BOTH my wipers and speedometer completely quit on me. I search TRS for days on the speedometer issue and tried everything I could to fix it. I replaced the ABS/VSS two times to rule out a bad sensor; checked all of the fuses located in the door panel and under the hood. I have no idea what the hell could be causing these problems. If anyone has any information that could help with this problem please, post them. Thanks guys...
Check fuse 26 and check the splice at your trailer light hook-up. Good luck!
Alright man, sounds good. I'll have to look into it tomorrow morning. If those aren't the problem, what else could be going wrong? Also, is there something, somewhere that is causing both the speedometer and the wipers to not work, maybe a place where they somehow get tied in together or one-causes the other not to work?
