Check gas cap light
Summers22
Forum Member
Kansas
Been fighting mostly a P0455. I have replaced the purge valve under the hood, the vent solenoid that connects to the vapor canister and a new Motorcraft gas cap. Recently I have been getting a P0457 and "check gas cap" light. I did buy a new vapor canister and vent solenoid because I have my doubts the solenoid I bought is working. After installing both I'll see where its at. How likely is there an issue with the fuel filler neck? Smoke test shows no issues. Thanks
the one on my 2000 rusted and leaked when fueling. the hose dry rots.
Yeah if I replace the entire inlet, then Ill replace the hoses as well.
I did a smoke test with the bed off and there were no leaks from the hoses. I think the flapper (which I think may be bent) never fully closes.
