- Aug 6, 2007
- Aurora Colorado
i kno installing better gears will help but what else can i do besides exhaust?
The cam is more about air than fuel, remember that old 14-1, or so, rule?After you get the air flowing better, you could change out your cam, and get the fuel into the cylinder a little more efficiently, but thats a bit of a tear into to manage that, not that you can't do it, its a simple task most anyone with a little experience can pull off.
Umm, no, unless your going to chill the fuel significantly below ambient temp.A fuel cooler can make a difference as well, if this is chosen to be done, make sure it is mounted in a place with plenty of air flow, cooler fuel burns better.
Again, no, the stock ignition system is more than capable of lighting off the mixture, even forced induction engines don't need an Accel coil. Any good set of wires and a set of factory recommended plugs will be fine.Then all you would have to do is ignite it. Accel makes performance coil packs for the DIS 2.3 (the goofy one with 8 plugs), you can match that with a set of 8.8 plug wires and a healthy set of plugs.
Best advice yet.KEEP YOUR FOOT OUT OF IT. The biggest reason you hear people saying that they didn't get any economy out of their rides is simply because the drive them a little harder after they mod them.
I'll give you that freeing up the intake and exhaust systems has some benefit but...
Best advice yet.
Once the flame front has left the vicinity of the plug it is completely irrelevent how "hot" the spark is/was. An accurate fuel mixture will not light off any faster or burn any better once a certain minimum voltage threshold is reached. The factory coils are above that point now. Buying "higher energy" coils is like pissing in the ocean, yes, your adding volume but, you will never see the level change. Now if you were running 20-25+ pound of boost I might agree but, even then a factory coil works fine.The ignition system upgrade is a highly suggested idea. Yes it is true that factory coils, pugs, and wires will ignite your fuel. The difference is how efficiently it ignites. Sounds petty and ignorant, but think about it a minute, most factory coils fire at around 30,000 to 40,000 volts. Thats a hot burn, and it will ignite the fuel usually right before the top dead center, the fuel goes boom and the hot exppanding gases shove the piston downward. Now if the fire is hotter, it will actually ignite faster, and more efficiently, shoving the piston with a bit more force.
How can Accel, MSD, Crane, Mallory, Pertronix, and even Proform GUARANTEE that there will be an improvement in performance.
OMG, I seriously can't believe that you guys are super moderators. Think about this simple fact. If upgraded ignition systems such as higher output coils, and multi-spark ignitons systems didn't work, wouldn't those companies be starving for money (look at the pathetic tornado air campaigne) How can Accel, MSD, Crane, Mallory, Pertronix, and even Proform GUARANTEE that there will be an improvement in performance. Half of the mentioned even go as far as to guarantee improoved dyno results.
The simple truth is that higher voltage improoves ignition, and creates a more efficient burn. Your dealing with hundredths and thousandths of a second, the more efficient you light the air/fuel mixture, the more time the gases have to expand, thus creating more power.
