Centrifugal Supercharger?
bathtub.toaster
Forum Member
Tifton, GA
Has anyone done this yet? I'm building a turbo 2.3 and I'm just curious if anyone has even tried putting a centrifugal supercharger on one. Would it be easier since you don't have to mess with exhaust manifolds or intercoolers?
For some reason this makes me think of electric superchargers.
But not like this:
If I remember right that's the belt drive units that have a gearbox attached to what looks like the cold side of a turbo? If so they work fine but sometimes they're hard to package... I haven't used one personally but we have at work in the past...
yes....lots of lima supercharged
Prochargers are the worst of both worlds.
You have a compressor that's only efficient & doing it's job during a certain rpm range AND it's sapping HP whenever you're not in boost.. not to mention the cost..
Wouldnt necessarily be easier than turbo either. You'd still need to find space to mount it and make brackets.. plumb the charge piping..
Youd really want an intercooler at anything above 5lbs too.. so consider the cost/gain ratio. 5lbs would be a 25%ish gain.. is that little gain really worth 3 thousand+ bucks and a bunch of elbow grease? I'd say no personally.
Go with a turbo and intercool it if you want more than 5lbs
OR
^^ get one of those.
You'd still have to build brackets & plumb the thing, but it doesn't cost many thousands of dollars and will give you boost throughout the entire rpm range
Mounting a 2.3 turbo setup is the easy parts. Tons of space and tons of cheap manifold options. The expensive part is when it comes down to aftermarket engine management...which you will need for any boosted EFI application.
