that looks like a fun ride, have to give you props on that one...is that from UA?
Highly disagree. Powertrax can say what they want but the No-Slip isn't smoother, it's worse, I'll never own another one.
The Aussie, lock-right and Detroit will all be similar in manners. I've had the Lock-Right, No Slip and Aussie and the Aussie is the smoothest and the No-Slip is the worst. My buddy (member "Grunizzle") recently replaced his No-Slip with a Detroit and much prefers the Detroit.
Many others can't complain about the No-Slip, and having owned all three of the lockers already mentioned, MY No-Slip is least noticeable to drive. The Detroit chirps and clunks all over the place. My Lock-Rite was noisy with all its ratcheting noises. But my No-Slip in my B4000 has never given me problems, its quiet, reliable and provides 100% lock up when I need it. And I can't remember the last time I chirped a tire. But every time I drive my dad's jeep which has the Detroit, you can't NOT chirp a tire. And it clunks at weird times with a noise that makes you question whats going on in the differential. Can't say the same about my No-Slip.........
The proof is in the video. The inside tire is spinning and the locker wasn't locked. Like I've said before I've driven the No-Slip in my Dakota and a friend's ranger (who now has the Detroit and likes it much more than the No-Slip), exactly the same behavior in both, I'll never buy another one, period. I never said the No-slip hasn't given me 100% lockup, it locks, no doubt about that, but the amount it lets the inside tire spin before it locks is unacceptable, and makes it intolerable to drive. I can hardly tell my Aussie is there.
Yeah...
I recently removed the synchro rings (What makes it different from other lockers) from the No-Slip in my Dakota and I like it 100x more.
Grunizzle's and mine worked just like Powertrax says they should work. The synchro system prevents the locker from locking when the wheels are traveling at different speeds (such as in a corner). In order to get it to lock while turning, the inside tire must spin and then match the speed of the outside tire. In a tight turn it's very jerky. Now with the synchros gone it works just like a Lock-Right/Aussie/Detroit. It instantly locks when I put my foot down and it's much smoother and more enjoyable to drive.Better now? I still can't wrap my head around why your No-Slip acted so much differently than mine other than you have a manual and I have an auto. But Gruinzzle had the same problem too it sounds like.
What ever the reason, neither of mine have every done what you describeI liked my No-Slip so much that I put another one in my explorer 8.8 this summer, and it drives exactly the same. It its quiet and engages smooth on tight turns. All is good for now, knock on wood.
So is it really that easy to just remove the syncro rings? Then what it acts just like a Lock_rite I presume?
