Another Keyless Entry Question
Featured Build Threads
ppeterso2
I have a 2000 Ford Ranger with factory theft system, power door locks, windows and keyless entry. I just replaced both door actuators last night and they work fine (whew, getting that first actuator off it's mount blind was a biotch! Tips: A. You need a stubby flathead screwdriver and B. unbolt that window regulator piece that's near the actuator!!!)
However I have the 2 original keyfobs that came with the truck and one (that I always use) works fine and the other (that I rarely use) seems dead (I remember that it quit working about 10 months ago). This morning I put a new CR2032 battery in the "dead" fob and it still does nothing.
My question is: If the battery in this nonworking fob has been dead for 10 months, would it lose its program? Or do I just have a dead remote??
PS- I know how to reprogram the keyfobs (ignition on and off 8 times and so forth) but don't want to mess up the programming on the one that works.
Thanks!
It must have lost the memory. Just program them both at the same time, one after another, the one that works first. If that doesn't work, the remote is bad.
Thanks Bert,
That's kinda what i was thinking--it makes sense to program the good one first. I plan to try that tonight when I can get home to the other remote fob.
Hello, I figured that I'd post an update:
Thanks Bert, your suggestion worked like a charm--both remotes were programmed within a few seconds! Now I know if that battery dies in the remote to replace it quickly!
Pete
Event Coverage
Featured Ranger Based Vehicle
