Winching is a last resort. Anytime one of us gets stuck on an adventure / off-roading we usually just recover the vehicle with a strap.
However, that only works if you have the room to move. I once found myself winching a group of people up a frozen hill on one of our winter trail rides. They couldn't get traction on it, and there was a curve at the top, so you couldn't do a straight line pull with a strap. Winching was the only option.
Those kinetic ropes stretch which means you need room to move, take up the slack and build energy. That might not be the best option if you're just pulling someone out of a ditch. You'll just end up dragging them down through the ditch.
Check out:
Choosing A Winch
What Most People Don’t Know About Winching
Warns Guide To Winching
Winching Tips
Winching Errors
Winching With A HiLift
Tow Straps – Hooks
Installing Tow Hooks 1993-1997
Installing Tow Hooks 1998-2011https://www.therangerstation.com/ov...-ranger-oem-tow-hooks-installation-1998-2011/
We have a bunch of articles on alternators and upgrading at:
1983-2011 Ford Ranger & Bronco II ignition, charging, and computer guides. Manuals, diagnostics, alternators, batteries, PATS, and fuse info.
Such as:
130 Amp Alternator Swaphttps://www.therangerstation.com/tech/ford-ranger-2-8l-130-amp-alternator-swap/
130 AMP Alternator Install
130 AMP Alternator Upgrade
200 AMP Alternator Upgradehttps://www.therangerstation.com/tech/200-amp-alternator-upgrade/
This one will give an idea of what Rangers came with what, and how to tell the difference:
Adding accessories to your 1983-2009 Ford Ranger may require you to have a bigger alternator to meet the demand.
If you're wanting to haul firewood in your Ranger, you should check out:
Ford Ranger payload capacity explained by year. Learn GVWR limits, Payload Package #2 ratings, and the risks of exceeding payload.
Start a build thread here so we can see what you have and what you're doing. There are a lot of knowledgeable people here that can answer your questions and point you in the right direction as you go.
