Advice needed moving forward
Featured Build Threads
I have only used my winch for dragging trees and tree branches around, it really doesn't take much to start sliding tires, especially if it isn't in 4wd. My truck is heavier than most Rangers too...
I just have a 8k Smittybilt.
It is incredibly nice for pulling down tree branches around the farm though.
Winching is a last resort. Anytime one of us gets stuck on an adventure / off-roading we usually just recover the vehicle with a strap.
However, that only works if you have the room to move. I once found myself winching a group of people up a frozen hill on one of our winter trail rides. They couldn't get traction on it, and there was a curve at the top, so you couldn't do a straight line pull with a strap. Winching was the only option.
Those kinetic ropes stretch which means you need room to move, take up the slack and build energy. That might not be the best option if you're just pulling someone out of a ditch. You'll just end up dragging them down through the ditch.
Check out:
Choosing A Winch
What Most People Don’t Know About Winching
Warns Guide To Winching
Winching Tips
Winching Errors
Winching With A HiLift
Tow Straps – Hooks
Installing Tow Hooks 1993-1997
Installing Tow Hooks 1998-2011https://www.therangerstation.com/ov...-ranger-oem-tow-hooks-installation-1998-2011/
We have a bunch of articles on alternators and upgrading at:
Such as:
130 Amp Alternator Swaphttps://www.therangerstation.com/tech/ford-ranger-2-8l-130-amp-alternator-swap/
130 AMP Alternator Install
130 AMP Alternator Upgrade
200 AMP Alternator Upgradehttps://www.therangerstation.com/tech/200-amp-alternator-upgrade/
This one will give an idea of what Rangers came with what, and how to tell the difference:
If you're wanting to haul firewood in your Ranger, you should check out:
Start a build thread here so we can see what you have and what you're doing. There are a lot of knowledgeable people here that can answer your questions and point you in the right direction as you go.
The bare minimum for winter recovery or other inclement weather/natural disaster use is a 3/4t full size. When I was a wildland firefighter, I drove a relatively ancient M37 military “Power Wagonesque” monstrosity.
Today’s rig of choice for said use? A gmt400 (OBS Chevrolet) K3500 (1t 4wd) c&c (narrow) dually. 350 that is most likely getting carbureted and coil in cap hei converted. Solid axle swapped (IFS is -useless- on a working truck), C60 (vintage Kodiak/Topkick) springs, Dana 60-70-80 front axle with manual locking hubs… 35-10.5-16 bias ply mudders since Power King 9.00-16LT are no longer available in the USA. More affordable/accessible/likely is 7.50-16 LT, the 14 ply bias version of an LT235/85r16… Rated to a 65mph top speed.
“Can” you use a Ranger/Explorer, CJ, YJ, TJ, XJ, Dakota, S10, Tacoma or similar? Of course. Should you? Maybe… Similar weight vehicle or smaller. Hyper aggressive ATs, 3 peak rated. Up armor your bumpers and frame. Add enough lights to the truck to see in pitch black, pouring down rain/ice storms. Max out your insurance coverage… We get ice storms, tornados, hurricane/tropical storm remnants, wildfires. Honestly, a minitruck isn’t suitable in those conditions. I started out in wildfire/storm response in 1987. I’ve completely destroyed a LOT of trucks in that time. If your Ranger is important to you, don’t use it for that kind of task…
Check out:
Choosing A Winch
Winching Tips
Winching Errors
Tow Straps – Hooks
Such as:
I appreciate you taking the time to respond with so many resources; I'll read through so that I can make informed decisions moving forward. :)
THIS “was” my inclement weather, natural disaster, search and rescue truck. The aforre mentioned K3500. That needs thousands of hours/dollars poured back into it…
jeeps and 1/2 ton 3/4 and 1 ton trucks like this is typically what i recover with my ranger.
back when i had a dana 28, i hated it because the joints were useless and thrashed out rapidly....and the 7.5 was a fail as well...along with the a4ld....
this was all corrected save for the a4ld with the 4.0 ranger.
a 4x4 4.0 manual trans ttb ranger is a tank. straight gorilla. only way it could be better is with a 4.3 gm v6 or a jeep 4.0 inline. the 99 as depicted here is a sla. so there were issues until live axles.
i would drag in all of the one ton haliburton support trucks and explorers while the dozer was dragging in the mixer and pump trucks regularly...in michigan bean fields through the 90s during certain times of the year for oil field operations...
for base recovery due to inclement weather i dont see a 4.0 ranger as a non option.
that said....my ranger does weigh 6000 pounds now... and is a hell of alot longer lasting between u joint and axleshaft replacements...with a non dana 28 and 7.5 axles.
it does have a 4l80 transmission and a f208 t case and a 6.x humvee engine as well.
but it was better all around with the dana 35....small block ford and 8.8 with 35,s....just 9-12 mpg was murder.
that dont get better with a 3/4 ton with a 4bbl.
the difference between 10 mpg and 20 mpg doing volunteer work with 3-5 dollar fuel is substantial. especially if you drive 30-50k a year just to go to work.
the irony with the ranger.....the best frame and mount systems were to 92....
the best powertrains were post 89.... the frames past late 92 metallurgy in the salt belt may as well be cardboard.... so your point has merit depending on conditions and locations as to the level of abuse left in a machine.... but that applies to all trucks driving the salt hell of detroit. 5-6 year old 1/2 tons can break in half here.
If I need to recover something in the winter... I go get the tractor.
It is about the same weight as my heaviest rig but it is a honeybadger in snow and seems to take pride in embarrassing 4wd's. It is nearly unstoppable if I go thru the effort to put the chains on it.
I can dead pull an F-150 out of a drift, unhook, spin around and plow out said drift. Oh no, the tractor is pulling towards the fence... just let me mash the left brake so I am dragging the drift that I buried my F-150 in while only really driving with one tire. Blade is on the back so I have to drive thru whatever I am moving... :icon_twisted:
A couple years ago I buried the wife's car, tractor ran out of gas plowing out the driveway and my F-150 was too awkward to get back where the car was. Ranger did fine breaking the Bronco to lead.
put tractor tires on everything.
but when tractor tires get stuck.
...that applies to all trucks driving the salt hell of detroit. 5-6 year old 1/2 tons can break in half here.
This is good to know, as I plan to move up there really soon. I'll buy something else for winters and save the Ranger for May-October.
Don't drive anything you like October-may
It's why I have gmcs. They are sacrificed to the commonwealth every year.
Event Coverage
Featured Ranger Based Vehicle
