Advice needed moving forward
RangerThings93
Forum Member
Bellingham, Wa
N/A
Other
STX
Vehicle
Drive
235/75R15
After reading through some articles on here and consulting ChatGPT; I think I'd like some advice from the community.
Goal- Adding a winch and possibly upgraded alternator. I want to be helpful in winter and pull people out of snow or get groceries/wood to the most vulnerable in my community.
Issue - My truck needs to be healthy. There's some tow equipment hanging out the bumper.
where do I start? When I start replacing the ball joints, axle, shocks I want to do all this with the intention of gearing for the snow. I love going out to junkyards and I use rockauto for shipping parts or my local Nappa. I uploaded the sticker on my door to ChatGPT and it gave me some useful info and explained what some acronyms/numbers mean. I still can't figure out if the model I have is an XTL or STX...
Here's what Chat said:
"Yes — this sticker is extremely helpful, and I can read quite a bit from it. Also, I need to correct one thing from my previous answer: the X in the 8th position of your VIN is what identifies the 4.0L V6, not the 8 I referred to earlier.
What your sticker confirms
Your VIN is:
1FTDR15X8PPB53388
That decodes to:
1993 Ford Ranger
SuperCab
4.0L V6
Built at Twin Cities, Minnesota
Production sequence B53388
And your door sticker gives us some additional goodies:
Sticker codeWhat yours saysMeaning
Build date07/93Built July 1993
GVWR5,040 lbMaximum loaded vehicle weight
Front GAWR2,740 lbMax front axle load
Rear GAWR2,750 lbMax rear axle load
TiresP265/75R15SLFactory tire size
Wheels15×7.0JFactory wheel size
TransmissionT4-speed automatic
AxleR63.73:1 limited-slip rear axle
VIN1FTDR15X8PPB53388Confirms 4.0L/4WD/SuperCab
The R6 axle code is particularly cool: it's a 3.73 limited-slip (Traction-Lok) rear axle.
And T is the factory code for the Ranger's 4-speed automatic.
But here's the interesting part about XLT vs. STX
Your door sticker does NOT actually have a field that says "XLT" or "STX."
That's important.
The sticker tells us the truck's factory mechanical configuration and various option codes, but the trim/package isn't simply printed on this label. So unfortunately, this sticker by itself doesn't settle the XLT/STX question.
However, your R15G body/type code is interesting. The label appears to say:
TYPE-GVWR: R15G
That corresponds to the Ranger R15 4WD SuperCab configuration. The VIN itself independently confirms the same thing.
So I would describe your truck as:
1993 Ford Ranger SuperCab 4×4, 4.0L V6, automatic, 3.73 limited-slip rear axle, with XLT badging and an STX designation appearing in parts databases."
Maybe look in the technical section on here to see if it talks about ways to tell the difference.
I don't know the difference between an xlt and an stx back in the 90s. I don't know if the stx was just like a sport version. So as an option on an XLT or an XL or a lariat, nowadays an STX is an XL with an appearance package, because that's what my 2024 arranger is.
To be honest with you, STX vs XLT is kind of a wash. I have seen both trim levels have the same stuff. someone says XLT has more crhome where stx hass painterd bumpers and what not. in the end, the trucks are the same. I think Ford markedted the STX to the younger/ more hip crowd and the XLT to the older people that want the niceties and comfort. STX will more than likely have more utilitarian interiors, but not always the case. I have a 97 Supercab XLT with the 4.0 and 4wd, pretty much same spec as yours, it came with all the goodies that STX came with (31" tires, bilstein shocks, off road package) and it has the full chrome. No STX decal or stripes, no 4x4 sticker on the bed sides like STX, but same truck.
Now for what you want it to do. First of all, you have the heaviest spec'd Ranger, and it is still going to be way undersized and light for pulling out anything that is really stuck in the snow, and especially anything larger than your Ranger, and you are likely going to tear your Ranger up in short order. If you want to be helpful in that way, I would get an F150 or F250, they will have the mass and weight to pull out a minivan much easier than a Ranger will. The Ranger will be more fun for you in the snow tho...
Just my 2 cents
AJ
Just my 2 cents
AJ
I appreciate your opinion, thank you 😊
get one of those stretchy ropes, and a damn good mounting point.
Stretchy rope is going on the list. I apparently already have two damn-good-looking mounting points on the front, although I’m learning there’s a difference between "RV tow me" and "yank that Subaru out of a snowbank". 😂
