- Aug 19, 2026
- Bellingham, Wa
- State - Country
- N/A
- Other
- STX
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Tire Size
- 235/75R15
After reading through some articles on here and consulting ChatGPT; I think I'd like some advice from the community.
Goal- Adding a winch and possibly upgraded alternator. I want to be helpful in winter and pull people out of snow or get groceries/wood to the most vulnerable in my community.
Issue - My truck needs to be healthy. There's some tow equipment hanging out the bumper.
where do I start? When I start replacing the ball joints, axle, shocks I want to do all this with the intention of gearing for the snow. I love going out to junkyards and I use rockauto for shipping parts or my local Nappa. I uploaded the sticker on my door to ChatGPT and it gave me some useful info and explained what some acronyms/numbers mean. I still can't figure out if the model I have is an XTL or STX...
Here's what Chat said:
"Yes — this sticker is extremely helpful, and I can read quite a bit from it. Also, I need to correct one thing from my previous answer: the X in the 8th position of your VIN is what identifies the 4.0L V6, not the 8 I referred to earlier.
What your sticker confirms
Your VIN is:
1FTDR15X8PPB53388
That decodes to:
1993 Ford Ranger
SuperCab
4.0L V6
Built at Twin Cities, Minnesota
Production sequence B53388
And your door sticker gives us some additional goodies:
Sticker codeWhat yours saysMeaning
Build date07/93Built July 1993
GVWR5,040 lbMaximum loaded vehicle weight
Front GAWR2,740 lbMax front axle load
Rear GAWR2,750 lbMax rear axle load
TiresP265/75R15SLFactory tire size
Wheels15×7.0JFactory wheel size
TransmissionT4-speed automatic
AxleR63.73:1 limited-slip rear axle
VIN1FTDR15X8PPB53388Confirms 4.0L/4WD/SuperCab
The R6 axle code is particularly cool: it's a 3.73 limited-slip (Traction-Lok) rear axle.
And T is the factory code for the Ranger's 4-speed automatic.
But here's the interesting part about XLT vs. STX
Your door sticker does NOT actually have a field that says "XLT" or "STX."
That's important.
The sticker tells us the truck's factory mechanical configuration and various option codes, but the trim/package isn't simply printed on this label. So unfortunately, this sticker by itself doesn't settle the XLT/STX question.
However, your R15G body/type code is interesting. The label appears to say:
TYPE-GVWR: R15G
That corresponds to the Ranger R15 4WD SuperCab configuration. The VIN itself independently confirms the same thing.
So I would describe your truck as:
1993 Ford Ranger SuperCab 4×4, 4.0L V6, automatic, 3.73 limited-slip rear axle, with XLT badging and an STX designation appearing in parts databases."
Your VIN is:
1FTDR15X8PPB53388
That decodes to:
1993 Ford Ranger
SuperCab
4.0L V6
That's important.
TYPE-GVWR: R15G
