buckshot
- Sep 6, 2007
I'm getting ready to put a '54 manual into my truck but have noticed a problem. The whole shift pattern seems to be moved about 1/2" forward. 2-hi works at the full forward position, halfway between where 2-hi and 4-hi should be is 4-hi, where 4-hi should be is neutral, where neutral should be is 4-low and the shifter won't travel any further back than that. All of the selections work, they just aren't in the right place... I can't find anything obviously bent on the shifter or any clear way of adjusting it. Any help you can render would be greatly appreciated. Thanks!
