'99 Ranger "lowered" 5.0L AWD to lifted 4wd...
Featured Build Threads
JoshT
⭐Supporting Member
💻 TRS Socials
Macon/Fort Valley, GA
GA - USA
Vehicle
5.0L
few inches
~30"
I think that seeing everybodys rigs at the 2026 Fall Colors Campout motivated me a little bit to get something going with the Ranger. Might not be ready for an event next year (2027), but at least it'll be moving in the right direction.
For those that don't know/remember (and I don't blame you) it's a '99 XLT extended cab 4x4, originally with 4.0L and auto. Was the first vehicles I bought myself, purchased in 2005 with about 95K miles on it. Couple of years ago dad and I did the 5.0L swap and I had the idea of turning it into a lowered AWD street truck. The game plan was always to give that a shot and if I wasn't happy with how it turned out to lift it. Well I haven't too happy with where I ended up, so it's time to move forward with the lift. Honestly, no loss as not much money invested into the lowering attempt, and I think I'll be happier with a lowered 2wd 1st gen for that (have a couple of candidates). Heres a couple of pictures of how it started, and how it was just before, during and after the swap.
Not long after purchase. At this point I'd only installed the brush guard, lights, vent visors, and new tires.
Several years later with a torsion twist, 32x10.5 on 15x8 wheels. I'd acquired a second hand Undercover Tonneau, nice cover, but didn't like having to remove to use the bed. Then with a high rise truck cap that I tried for a little while, still have it out back and might give it another go if I devise an easy on/off system.
During the V8 AWD swap and lowering. Set of 18" explorer wheels and as low as it could go and still be drivable in front, but really needed longer upper control arms that weren't available. First picture rear is flipped spring under with extended shackles and maybe Explorer springs. IIRC yes, the axle is further back than it should be, that was intentional at the time. Second picture it may be back at stock 2wd height. The front would actually go lower, but the camber was so bad that I couldn't keep it like that. Needed a set of longer control arms to help with camber and extreme balljoint angles, but no one was making them at the time.
After that I actually raised it back up a bit in front, reinstalled the stock wheels and stockish size tires I was running prior to swap, and was going to run it like that until I could get someone to make me control arms to lower further. Shown here sitting next to a random stock 2wd second gen. Rick's Rangers eventually put the arms out late last year, but by that time the plan was pretty much set to go back up. Combination of being underwhelmed by the performance/handling and mom insisting that I get dad's F-150 Ecoboost which was quicker/faster, more efficient, and more comfortable.
These are pictures I could scrape together through the present. Still sits like those last couple of pictures. Been parked most of this year due to a parasistic drain, brakes needing attention, being focused on other projects, and simply not being sure what I wanted to do with it.
As I said in the Fall Colors Campout thread, I'm not much of a picture taker, so don't expect too much going forward. That said, I will make an effort to take some as I go along.
With that abbreviated history out of the way. Here's what I currently have in mind:
  • Explorer 5.0L ✔
  • 4R70W ✔
  • 4406 electric shift
  • Explorer 8.8" disc brake axle
  • Live axle conversion ✔
  • 04+ (IIRC) 12" brakes
  • Rough Country 5" lift kit
  • BTF Fab upper arms
  • Lift springs instead of blocks
  • Coil-over conversion
  • 33" AT tires
  • 16-17" wheels (lift kit calls for 17")
  • 01-03 Edge front end
  • Off-road bumpers, maybe with winch... just cause
  • Some interior changes like different seats, center console, etc
As noted in the opening, the 5.0L swap is already done, though it might need some attention. I'm not certain about the engine itself. It's healthy and runs good, but I'm not sure that the intake, heads and cam are the right combination, or maybe the tuning just isn't right. The transmission is at or over 200K miles, so I want to put in a fresh transmission with a shift kit (or J-mod?) before I worry too much about the engine, because who knows how that may be hindering things. Want to swap the AWD t-case for a true 4wd case, staying e-shift since my factory controller should handle it. Live axle swap was also done to go with the AWD drivetrain.
Along with the transmission and transfer case, the first work that will be done is the lift kit and tires. I know that 33" tires can be run with stock suspension, especially with the coil-overs, but I've read enough about these trucks that I'd rather run the lift kit. Better angles for the CV axles and ball joints, and I'm not using up most of my down travel to achieve the lift. Also gives more wiggle room if I want to get a little stupid down the road (35s anyone?). Doing the lift first with the transfercase swap will let me measure for and buy driveshafts once and I won't have to be rebuying tires later to move up. I need to get the suspension parts on hand so I can check wheel clearance to see if I can actually get away with a 16" or will have to go 17". If I have to go 17" it might be some Mustang wheels with spacers initially until I decide on something I like. The 12" brake swap is required by the lift kit, but was already on the to-do list for next time it needed them.
I'll probably be sticking with the torsion bars and lift blocks initally to spread out the costs. If the transmission and 4wd t-case don't make the improvements I hope they will, I might be spending some money on top end and tuning before it goes back into suspension. Long term I definitely want coil-overs and lift springs. Doing the lift first will let me get ride height dialed in where I want it to get measurements. Also with the lift, the torsion bars won't ride like a wagon until I can get the conversion done. The lift kit comes with all the parts and shocks anyway, so might as well use them for a little while.
Other bits will happen as I get to them.
I have a a couple of Explorer 8.8s, but they are both 3.73 ratio. I've also got a 3.73 front diff, but unless it's a good match to the 33s and 5.0L (doubtful), I think a regear is in order. Want to see if I'm happy with the 4.10 or want to go shorter before I invest in that. I'll also be watching the yards for a 4.10 ratio Explorer axle, but not afraid to use the Ranger axle until I get around to the swap.
As seen in the pics above, the powerdome hood is installed. I've got a line on a free grill, need to follow up on that if it isn't too late already. Leaning towards the some of the weld-it-yourself bumpers (AOR, Move, Costal, etc) maybe a swing tire carrier on back for a full size spare. Definitely want different seats. Have a set of Flow-Fits (think early Saleen Mustang) in storage that I bought for the first gen, and brackets for putting aftermarket seats in the '99, so might use those temporarily. Maybe later model Mustang for more long term solution? Got an Explorer console I was planning to install, might go with a short console instead if I can find a decent one. New carpets and general cleaning. Paint... maybe someday.
Sad to here this. I was looking forward to seeing an AWD Street Ranger, since I also abandoned my project. That 1st pic , with the Explorer 18's, is exactly the stance/look i was going for.
NOTE : I still have my donor explorer, if you ever need any engine parts AND are in the North Florida area, you're welcome to pick anything off of it, no charge to any TRS member.
Can't say that I don't have reservations about not finishing the street truck project, but I also don't really want to continue it. Realistically there are several ways and places I can play with a 2wd or 4wd toy around here, not many places around here that I need or can really utilize an AWD. Ultimately I just wasn't happy with combination at the point I got it to. If I could have fixed the suspension issues back then, new transmission, probably a regear to 3.73, and proper dyno tuning, I'd probably have liked it a lot better. Vehicles, situations, and interests have changed since then.
The F-150 is quicker and more efficient than I'll ever get this Ranger to be, and I'm not going to be using it as a trail or hunting truck. The F-100 could definitely be a beast offroad, but it needs a lot. I'd like a lowered first gen 2wd to eventually replace my car, that's what the '85 was for, but I'm not sure it's going to make it (rust and general condition). Also thinking about turning the '86 Ranger parts truck into a cheap auto-x and drift thrasher. I've got too much and it's going to take me a while to work through all of them.
What I'm not going to have is a good truck for hitting trails, rough roads, and hunting. The F-100 would be good at that, but I want to make it nicer than an offroad toy, it can't pass a gas station, it doesn't have AC, and it's going to take a lot more time and money to make it that relaible. The '99 is the best option to fill the void. Once I get the money set aside and parts acquired, it shouldn't take me long to at least get the initial phase of work done. That being the initial lift, transmission, transfer case, and tires.
FWIW a combination of the rear suspension in that first pic with the front down like the second pic is about what I wanted. Functionally the rear was too low for the parts I had, and the front needed longer control arms as mentioned to align the front. The rear axle was actually offset about an inch to the rear because the driveshaft was too long to fit in the proper location. The holes in the flip brackets I had were redrilled (by previous owner) to move it back and the driveshaft was still at max compression. At that height the exhaust shop couldn't get clearance to run dual exhaust over the rear axle like I wanted. If the control arms and exhaust had worked out better, I'd have been swapping in an Explorer axle. and finding some wheels I liked better.
Keep an eye on lil_Blue_Ford, he's still building one. I imagine that once he gets finished and if I ever see it in person, I'm really going to wish that I'd continued. Maybe I'll try it again someday with a RCSB and maybe something like an ecoboost, but a shop and the other projects will have to come first.
@lil_Blue_Ford , the offer goes to you also. If you're ever in the area and want to comb over the Expo, LMK.
Probably going to be awhile before I’m in a position to make a trip down that way but I appreciate it and my plan has been to make a few trips down to more rust free states for vehicle stuff
Also, yes, I’m still trying to get my 5.0 AWD lowered Ranger together. I keep trying to work on it and keep getting pulled away from that project so it’s been a struggle this year to try and get it done. Going to try to make a serious effort before winter though.
or. leave it low. twin turbo 3.7---10r80.
would be an animal.
would be an animal.
Not this one....
I'm not saying that I'm giving up on a lowered AWD Ranger 100%, just that I'm giving up with it on this particular truck. I was doing the build with this 99 extended cab, but for me the idea didn't start with it. That dreaming and scheming is lost to previous versions of the forum and a different user name. Back then I was actually thinking to body swap an older square body to a 4wd SLA frame and build from there, and more recently the idea for an ecoboost and manual or modern paddle shift automatic snuck into the ideas list. At the time I was no where near prepared to tackle something like and, although I'm better equipped, I'm still not.
For now that's stuff to write down in the wish book, to be revisited when other projects are squared away and I've got a proper place to do it. I don't really want to get off the rails on that in this thread, or at all right now. Need to focus on current projects and not get sidetracked by stuff that might happen someday. Fixing/building/maintaining the current trucks, then building shop and a house come first. Yes, the shop and house are kind of in that order, the trucks will be kind of ongoing through all of it.
I spotted something on marketplace that might have my shuffling the plans a little bit.
The goal is a 4wd, lift, coil overs, and 33s. Getting 4wd and back to stock height would be a huge step in the right direction. I can do the 4wd for the cost of the transfer case and some driveshafts. It was looking like I would have to get the driveshafts anyway as donors for having the correct length made, so not major loss there. Getting back to stock height is as simple as reinstalling the stock keys and lifting, and throwing a set of extended shackles in the rear (instead of blocks). Would be caple enough for any offroad oriented trips I'm likely to take in the next year or two.
The reason... I might have found parts for one of the other projects.
The 85 in my sig is destined to be the replacement for my current daily driver, if I can ever get it there. There will be a thead for it when the time comes, might have even started it already. Plan for it is kind of a Factory+ refresh. Some of the higher trim line options and some what if or ford should have upgrades. Clean it up, dress up the interior. Lower it and upgrade brakes. A perky (maybe even energetic) 2.3T. Still collecting parts for the clean and dress up part, but that'll be ongoing even after I start driving it. Have everything for the lowered and upgraded brakes, but truck isn't running and needs a floor pan, so haven't been in a hurry to get it running and lowered. The 2.3T part I've barely started trying to figure out. Well I started looking into it and have a general idea, but decided I needed to complete some other projects before building a 2.3T from scratch.
Well there is a chance that the build from scratch part might be out the window. Spotted non-running but mostly complete Thunderbird TC on Marketplace for $1000. According to the listing it will run on starting fluid, but there is no fuel tank installed. Seriously considering contacting seller if its still there this weekend. Been brainstorming how to get it home. Got a trailer, but not currently good way to get a non-running car onto the trailer. Maybe get my hitch mounted winch wired up finally, maybe temporary fuel tank to make it run, or maybe a tow rope and a second vehicle. We'll see if I do take a shot at it.
Ranger build is still on, just some parts might be delayed for a bit. I did make some progress with scouting for this project. Stopped in at the local u-pull-it and there are plenty of F-150 4406s to choose from. Unfortunately none of them had the already removed option, or I'd have figured out how to get it into the trunk of my car. I've just got to figure out how I'm actually going to get one out of the truck with out a floor jack, and see if I can find any driveshafts. There were enough that I can take a few weeks to figure that out.
Thunderbird sold last night so that little detour is gone... for now.
Rough night/morning and I'm tired, so not much got done today. Did check up on the Ranger's battery situation when I got home. Since then I've been doing the sit and click side of the project, studying and parts hunting.
On the battery.. It's been sitting untouched for two days since it came off the charger and it's dropped into the mid-low 40s both nights. Battery still showing a full charge, which doesn't really suggest a bad battery. Doesn't really suggest much of a draw either, so I broke out the multimeter and checked for a drain. Showing less than 0.2 amps drain, so there went the big parasitic draw theory. Checked the alternator output, about 14.5V under load. Looks like I don't have much to worry about as far as battery and charging are concerned.
Notes from my studying for future reference.
1) The 4406
  • Electric shift (4406E) from a '96-'08 F-150.
  • If your Ranger/Explorer uses VSS in rear axle for speed, like my '99 Ranger, you can use any of those. From wehat I understand if you need the VSS in the transfer case, you need one from a '96-'98(?) F-150. I haven't done much research on that second part since it does not apply to mine.
  • Avoid an SUV 4406 unless you can confirm it is 4wd only (2, 4H, 4L) and not TOD or 4WD Auto (4A, 4H, 4L). The TOD cases have extra clustches and parts in them to make the system work, and need a different control setup. It may be possible to swap in the control system to go with it, but you're on your own there.
2) Front Driveshafts
  • Stock height Ranger/Explorer use 97-03 F-150 4.6L front driveshaft.
  • 1310 to 1330 coversion joint with Ranger flange for front axle.
  • Maybe a 5.4L 4R100 driveshaft for the lift? It's a few inches longer than the 4.6L version, so it might be worth trying.
  • Was told I'd need a Double Cardan for the lift kit due to angles. If the length is good, possibly have the longer shaft modified with one?
3) Rear Driveshaft... Probably going to have to get one made/modified, but I'm might experiment a bit. Here's what I've got, will edit and adjust as I find more.
  • There's allegedly a bolt in rear shaft for the 4406 into an Explorer, the 97-02 Expedition/Navigator 4.5L 4x4 shaft. Not sure if that is standard suspension or air ride on the Expedition. According to parts listings, the air ride is the same 46.125" length as Explorer, but one has a slip yoke and the other has a flange. Looking for clarification on that and going to see if I can find something similar for the Ranger to try out.
  • 99 Ranger extended cab 4wd shaft is lsited at 61"
  • Some 97-03 5.4L F-150 4wd have a 63.75" shaft (4R100 I think)
  • 09-11 4.6L F-150 4wd lists 59.5" and 60.5" shafts
  • 09-11 5.4L F-150 4wd lists 59.5" and a 57" (might be handy for someone going lower or a shorter wheelbase)
  • 09-11 6.2L F-150 (Raptor?) lists 66.125" (might work for a lift?)
  • 09-11 F-150 uses same yoke at transfercase and a larger 1350 u-joint. No conversion joint available for Explorer flange. Maybe a different companion flange or larger pinion flange available.
On the V8 Explorer you use the 5.4L rear driveline out of an expedition, the rear output on the 4406 is a few inches further back than the AWD case from the V8 Explorers. Honestly I didn't measure any drivelines when I swapped my explorer to 4x4, I just took the internets word for it... lol
I don't remember the wheelbase comparison between a 4 door explorer and an extended cab Ranger... I can measure my explorer if needed...
Not necessary.
A stock 5.0L AWD Explorer and a 4406 swapped 5.0L Explorer have the same wheelbase. The only difference relative to the rear driveshaft is location of the transfer case output. The difference in driveshaft lengths gives the information I'm looking for.
Combine that with the fact that the Ranger uses the same driveshaft before and after the AWD V8 swap. So if the explorer with 4406 uses the same length driveshaft as it did with the 4404 (AWD case), it stands to reason that the Ranger would too.
That said, at the moment I'm not sure I ahve the right information for the Expedition shaft that fits. Doesn't make sense that the same length shaft would fit when the 4406 is probably longer than the 4404. I need to verify and/or find some more info.
I've also found reference on another Ranger forum that someone with this swap on a '98 Ranger extended cab long bed with the 5.0L swap and 4406. They said that they were able to use a shaft a 97-03 F-150 4.6L regular cab short bed. That comes in right about 50" length.
A lot more reading and figuring to do.
As luck would have it I have 3 Explorers, one 4406 swapped, two stock and have the loose shafts out of the 4406 swapped explorer and a spare 5.4L shaft to swap one of the stock ones to a 4406 (I have way more use for true 4x4 than awd and planned accordingly).
I know the wheelbase stays the same but the rear shaft length obviously changes... since you have the 4404 now the length difference between the two rear shafts in the explorer application should help I'd imagine... just now thought it through.
Y'all are probably getting tired of the word to picture ratio here. Going to need you to bear with me for a while longer. I think I got an updated plan of action in work here.
The reason for doing new transmission, 4406 swap, and lifting all at once was cost. It was going to be expensive, but I thought it would allow me to to avoid things like having to buy driveshafts twice. I don't know if you've looked but a new off the shelf drive shaft for these applications is like $3-500 each and I'm probably going to need two custom shafts made for the lift. Doing the swap at stock height first would require a nother set of shafts in addition to those, a n off the shelf unit for the front, and possibly a custom for the rear. That's on top of a ~$3k transmission, $500 transfer case (assumed), $1.5k lift kit, and $1k+ tires. Looking at $7k+ for all of it, so if I could avoid rebuying parts it was worth it.
Finding out that I can get a used transfer case and both driveshafts (assuming the F-150 works) for <$400 changes things a little. I can actually break it up into smaller projects without doing a lot of rebuying parts.
I can start with replacing the tired transmission, and do the 4406 with the used parts. I think those things alone will vastly change dynamics of the truck, because I think the trans and/or AWD os a large part of what's hindering it now. If the rear shaft doesn't work out, I can stick the AWD case back in and run the shafts I have now until the lift happens.
Once I'm happy with that, I can start lifting. Since I'll already have shafts that work with the 4406, I can measure and have them modified to fit the lift, or maybe even find different factory shafts that work.
While collecting parts for the lift, I can start on the modifications required to fit coilovers, then its just a matter of measuring for them once ride height is set. The break will also let me make a better assessment of the engine itself determine what needs to be done there. Probably wouldn't be any more satisfied with things if I put big heavy tires on an already underperforming engine.
Event Coverage
Featured Ranger Based Vehicle
