99 Ranger build
99 Ranger build
Got the 37s mounted and put on today. Its a big change from the swampers but the ride and handle so much better.
They look awesome! Are you enjoying the lack of road hum?
Sent from my iPhone
Thats a plus, i can hear the radio now. But the best is not having the morning flat spots on the tires.
I need one of those.
Im doing a dana 44/60 swap in a month or two and was wondering if you did anything with the master cylender or if you just ran lines to the axles and they were good?
I still have the stock master on. I just removed all the abs stuff and ran the lines straight to the wheels. If i have to i can lock up the wheels on the highway.
How do you like the spool in the front? Does it steer hard with the stock steering pump?
It does make it hard to turn some times, but most of the time its not that bad. Plus its alot cheaper. If i had a choice to put one in again i would.
Okay one more question lol. what high steer arm did you use and who machined your knuckle?
Sky offroad is where i got the arm from and also had them machine my knuckles.
Alright thanks for answerig all my questions. Im sure somethig will come up during my swap and ill have more lol
Stretching her legs at work today.
99 Ranger build
99 Ranger build
I work at a under ground silca sand mine.
