My buddy has the 3.0 auto and his truck is a drag with 33" all terrains. I can't even imagine your situation. I have 4.0 stick so hopefully I can survive with 4.10s on 35s long enough to afford new gears and not blow the trans
U wont be using the vvs plug that went to the rear axle anymore. The t-case uses a differnt style plug. The case should be from a 95-97 ranger and has a 2 wire plug harness, the wires should be 1 gray with black stripe and 1 pink woth orange stripe. Make sure if u get the harness from a junk yard u get a good 6-8in if not more for splicing.ford78: when you put in your new t-case did you have to buy an adaptor for were you plug in your vss or did you have to splice wires? or did yours plug right in? Mine looks like it has a different plug.
You will be then splicing into the ABS Harness that goes to the abs module.
Open open up the harness and their should be only one Gray with black strip
wire. Cut that wire and entend the harness side of the wire down to the t-case vss sensor and connect it to the gray/black wire to the vss sensor. The pink/ orange goes to a good ground.
