99 4.0 lower control arm rear bolt
Featured Build Threads
California
99 ranger 4,0 replaceing the lower control arms , Passenger side the lower control arm bolt to the rear hits the exhaust pipe . Unable to remove, driver side went smooth any ideas
Is it 2WD or 4WD ?
how much room do you need?
3 options, or rather my 3 best guesses
remove the exhaust pipe, use as a last resort. I'm in the rust belt so I'm slightly biased against touching a rusty exhaust bolt.
raise the pass side engine, loosen 2 mount bolts and jack it up carefully
have a new bolt available? cut the head off the old and pull it out backwards
Upcoming TRS Events
Featured Ranger Based Vehicle
