95 xlt
Featured Build Threads
bootlegkev
5+ Year Member
stroud,ok
96 xlt 4.6 swap
i have a XLT 96 ranger i'm going to swap the drive train out of a 94 Lincoln Town car. will my trans mounts be the same. mine is a two wheel drive 4.0 im putting a 4.6 litter out of the town car in it...the car was a rare find it has 40,000 miles on it.. i would like to know if my mounts will the same.. and if possible how much of a power difference there will be... thank you
Welcome to TRS :)
No, motor and transmission mounting will need to be changed
1996 4.0l OHV V6 was rated as 160HP and 210ft/lb torque
1994 4.6l was rated as 210HP and 270ft/lb torque
IMO sell the low mile 4.6l and transmission and get a 5.0l V8 and trans from Explorer
It fits and has same HP and torque as 4.6l, actually slightly more
Explorer 5.0l V8 was rated as 215HP and 280ft/lb torque
Good read here on the 4.6l engines, there were a few different models: https://www.therangerstation.com/how-to/engines-fuel-systems/the-ford-4-6l-281-cid-engine/
If you scroll down about 3/4 of the way you will see Engine Dimensions
The 5.0l(302) is 19" wide and BARELY fits between heater box and steering shaft in a Ranger
The 4.6l SOHC is 28.5" wide!!!!, so you will need to move the steering shaft, and modify the heater box quite a bit
So alot of extra work for same or slightly less power than the 5.0l Swap which has been done many times before, so lots of tips and info available
Ford used the 4.6l V8 in a few models, maybe you could find one with clean body and interior but bad engine/trans
Swap it out and sell it to fund the 5.0l Ranger conversion.
Just an opinion
Thanks for the Advice I happen to have stroker kit for the 4.6 so I'm kinda stuck ... I'm just a poor boy too. .. thanks for answering my question
Event Coverage
Featured Ranger Based Vehicle
