94 ford ranger zerk fittings
Featured Build Threads
edwardhawkins37
5+ Year Member
Canton, GA
4.0L
Hi! Does anyone happen to have a diagram should all the grease zerk fitting locations on a 1994 Ford Ranger?
Thank you.
Take a look in the Tech Library... there are owners manuals there that will probably have that info.
OEM, there aren't any.
By 94 (and earlier) they were building vehicles with prelubed, nonservicable parts. Best thing is to get under there and look to see if a previous owner replaced things parts. Look at u-joints and steering/suspension bushings.
I just thought of that too... the entire lubed for life thing...
But as stated... a lot of replacement parts have grease fittings. Just dive right in.
IF there are any zirc fittings, look at the outer tie rod ends, upper ball joints, lower ball joints, and drive shaft u-joints. If the parts are factory original, the chances are next to zero that they had any.
Upcoming TRS Events
Featured Ranger Based Vehicle
