89 2.3 clutch line wont connect
Featured Build Threads
dkeys
10+ Year Member
fredericksburg va
i just got done installing new slave and master cylinders in my 98 2.3 2wd ranger and i can not for the life of me get the old clutch line to connect with the new slave.
the old slave had a shiny blackish female connector, the old line has a black male connector.
the new slave has black female connector.
Ive tired opening the bleeder valve, i tired the old o ring, i tired brute force, it will not click.
ive done several clutch replacements on rangers and never ran into this problem. i would really appreciate some helpful advice
Mube up the fitting on the line with PB Blaster Carefully get it moving with a pair of slip joint pliers, Work it until it works easily, then hold the female housing back and push in the male. Good luck. In a way I was lucky, the steel part of the hose was rusty, so I bought a new one, which worked easily :D
thanks andy i will give that a try and let you know how things work out.
I have no clue what i did different after work today but the hydraulic line snapped right into place like it was supposed too. i guess i just needed a few hours away from it. but thanks for the help andy d your advise was next on the list of things to try. gotta love owning rangers they keep you busy thats for sure. but once there running right they last FOREVER.
Event Coverage
Featured Ranger Based Vehicle
