- Sep 11, 2007
- Age
- 41
- Sparland IL.
and so the frame on the bII is clean from all the ttb junk. And since there are ways too many red rangers out there and not enough bII's, and since I <3 my bII, I'm going to build the bII. It saves me a lot of hassle plus its what I truly want. I'll stretch the wheel base where I can and live with what I end up with.
So anywho after getting all the ttb off i put an exploder leaf pack on a jack and held it here and there and this is what I am looking at.
This is the explorer leaf on the utmost forward position I can mount it. Some tabs off the front or bottom of the bumper would work this is doable.
This is then how forward the axle would be pushed- I like it.
Now this is where I gotta come up with something. This is where it would leave the rear.
(This picture was taken at an angle and is decieving. The eye of the spring is almost centered under the body mount bolt, it's a tad closer to the front of the truck)
That is right under the body mount. Options:
a. Johnny U has his chevy parked in my front yard and I was doing some measuring on his ORD rear flip kit shackels. The hanger is off-set on the mounting flange, biased to a side leaving just enough room to have bolts in it. If i used a pair of these it would allow me to mount a hanger in front of the body mount, but as far back as possible. It is also a drop hanger so the shackle would not interfere with the body mount in its travel. WIth the shackle angle toward the back of the truck, and the leaf swinging down to meet it, I think it'd come together. But that would put the rear of the spring a lot lower than the front of the spring and I wonder if that'd mess up pinion angles or give me a fugged up shackle angle.
ORD shackle flip kit.
b. home made leaf pring bracket under the body mount.
c. use the ord hanger but without shackle, then go front shackles and hang them off the front bumper.
