85 BII Premium Sound Update
Featured Build Threads
ford4wd08
5+ Year Member
Maryville
TN - USA
Drive
2.8L
Thinking about replacing my receiver in BII I daily drive because I am tired of hunting the radio stations each time I get in when there is a temp change. I do know it is a premium sound setup with what I assume is an amplifier in the dash under the cover with the bolts.
I have already changed out the speakers in the dash and the body panels behind the front seats.
Trying to find an appropriate looking head unit that doesn't look like it belongs on a spaceship.
Anyone done this change recently, got any leads on good replacements?
I believe '85 is the first year of the single DIN radio size vs the '84 and earlier RBV's.
@RobbieD any advice on this?
Current Radio in BII.
  • 85 BII Premium Sound Update
Yes, 1985 was the first year model with the single DIN head unit.
If memory serves, the OEM opening may need minor filing to front-load an aftermarket single-DIN head.
I hope that somebody comes along with suggestions for the head unit, as I'm in the same boat as you.
I have three trucks, a '90 B2 and 2 '94 Explorers, that I would like to get matching AM/FM/CD head units. They all have the same second-generation dash.
I doubt that I can find three working Ford head units, that vintage, that are working and affordable. So I'm going to be looking for a basic, no frills black faced head unit, current manufacture, that I can put into all three. Until I start looking, I'm just afraid that nobody's making such an animal anymore.
I kick myself, for not stocking up on such units when I installed "back in the day". Some of the old Blaupunkt and Sony units looked right at home in these trucks.
My '84 still has an uncut "3 holer" dash panel, so it's got an OEM Ford AM/FM in it (a shafted radio). Unmolested '83-'84 dash panels aren't easy to find anymore.
Have you seen this Pioneer unit that came out last year?
I think they did a great job for the styling, but it's pretty high dollar, might only be available in the EU as well.
Factory radio converted to Bluetooth.
You can find decent looking Blaupunkt units on ebay, but they're not exactly cheap either.
I've technically got BT currently with my radio, but it is through a hardwired FM transmitter that plugs in through the port of the antenna, it works great unit you hit a bump and loose the FM station :D
I forgot about it until recently, but I rented a U-Haul truck a couple of years back and thought the receiver in it would look decent in an older vehicle, but I have no idea what the part number is or if it would be an easy swap. I snapped a picture of it though.
Thanks. I had not seen that one. The look is nice but . . .
I just want a simple AM/FM/CD unit. I don't need Bluetooth, nor even any kind of USB inputs.
Simple digital readout; hell, I could even dig an analog dial for the radio part. Four-way balance / fade, separate bass and treble. That's it.
Shit, I don't even have a cell phone at the moment. I don't want one, either, but I do need to get a flip phone (easier to carry) though, for possible emergencies considering my age, health and my alone and rural living location.
Basically, I just want something to fill the hole in the dash, that makes pleasing noises.
Oh man....
Analog radio, no cell phone, and planning trips with a paper map. I miss those days.
Oh man....
Yes; some of us choose to still live this way.
A simple life, is a happy life.
So... After so eBay searching, I decided to go with this Kenwood KRC140 radio.
Seller seems to be honest and it seems to be a decent era correct unit anyhow. I can still use the Bluetooth setup I have in the BII now and this should be a decent upgrade from the stock unit. I think it will look fine installed as well.
Hmmm. I'm going to have to look at my stash and test them. Might be a gold mine...lol
Sucker born every minute right?? :D
It amazing what people, including me, will pay for something that is a few decades back and still works.
I couldn't stand the thought of the newest single din units in my BII with all the bright LED's and crap that came with it.
Ever since the early 90's the manufacturers decided to make new radios as gaudy as possible in my opinion, that's why they new retro ones are coming out and brining a lot of money new.
So, I got my new to me radio in and tried to install it tonight.
Ran into some issues and I believe it has to do with the Premium Sound.
I bought the metra wiring harness:
And it did fit the plugs from the old radio, but the radio did not work once wired up. I figured out that the yellow wire on the radio side was not getting constant power (the memory function wire) and made a jumper from the keyed ignition to the memory wire and it worked, but I got no sound from the speakers unless it was turned all the way up and it really didn't register much.
I think it has to do with the amp in the dash, so I would like to remove it.
Does anyone have the wiring diagram from the 85 premium sound system?
Im going to just go to wires from each speaker to the back of the radio and be done with it.
Didn't know if premium sound was something that was an add on harness to non premium system or had its own harness all together?
If I can't figure it out I'll go to each speaker and look at the wire color and trace them to the dash and cut them to make my own harness.
Featured Ranger Based Vehicle
