4.0l SOHC tensioner going?
Fridge
Forum Member
N/A
PE - CAN
Other
1968 Charger, 2005 Camry
Vehicle
Drive
Stock
none
First post here, and likely not last.
I have a 2001 Ranger with the 4.0l SOHC engine with around 118000mi on it. For some background I bought the truck a year ago from a guy who adored it and it was serviced to a T, with some questionable fixes that aren't major.
I do not know if he has put in the fixed guides and tensioners, not that it matters too much at the moment. A few months ago I heard a tick on back of the engine, not loud at all, knew these engines had timing chain tensioner problems. You can hear it from both sides if you lean your head down on hood. I'm just wondering if this is the dreaded tensioners, and if I can put off the repair until spring comes around (it's cold outside I don't have a garage). Any help would be appreciated! Thanks.
Linked video of it idling:
The video is telling me I need to sign in even though I'm already signed in and listening to youtube while on here. Is the video set to private?
In anycase, if you have no record of the tensioners being replaced, assume they haven't been replaced. The mileage you quote is a bit longer than we recommend on here for changing them but not horribly long. Change them about every 70,000 - 100,000 miles. I prefer every 70K.
I made it public now, should work hopefully. But yes I was just waiting for a sign to change them, and I think it is now. I daily drive it so I hope they can go until spring.
I didn't hear anything that seemed out of the ordinary to me.
Yes if you listen too closely you're going to hear all kinds of noises. That ticking is probably the injectors I had the same trouble with my engine but I believe I was worrying for nothing.
Thanks for the clarification! I couldn't tell if it was just normal engine noises or the tensioners as I have no experience with the 4.0l sohc. Should the tensioners be replaced sometime soon anyway or should I just wait for them to make some noise?
I ike to change the tensioner and the idler pulley while I have the belt off. I keep the old parts, as long as they look and feel decent. Since more often than they should be, new parts aren't always good parts.
I don't wait for them to start making noise.
118,000 miles is the perfect time to change the hydraulic timing chain tensioners. I wouldn't wait for them to start making noise. You're already ahead of the game since you know about the potential issue with these engines. If you replace them now you should get many more trouble free miles.
I replaced my hydraulic cam timing chain tensioners at 100K miles the first time and then another 150K miles (250K total on the engine) when I replaced the second one. Both times the old ones were still in good condition. It is still a good idea to do them at 100K intervals as a precaution.
I am at 312K miles now everything is functioning like new.
312k, that's impressive and goes to show you what good maintenance will get you.
I just replaced mine (115k) and will definitely be replacing them again well before I hit 200k. Cheap insurance.
