302 to v6 tranny bellhousing??
Featured Build Threads
nford824
5+ Year Member
hello, i have a question, im getting a 302 for my 86 4x4 manual trans ranger and i think ghe 302 will work with the stock tranny, the engine in it is 2.9 v6. does anyone know what bellhousing i need to bolt them up?
Welcome to TRS :)
I wouldn't recommend it because of the power differences, pre-1990 V6 tranny was made for about 150HP, and much less torque.
You will need to check which transmission you have
read here: http://www.therangerstation.com/tech_library/ManualTransmission.shtml
Summit has an adapter for SOME Ranger models, here: https://www.summitracing.com/int/parts/add-712541/overview/
You will also need a 302 bell housing
Once you have a price look at the price of a trans and transfer case from an F-150 with 302, which IMO would be money better spent for long term use
Welcome to TRS :)
my truck has the fm-145. i found a good deal on a rebuilt 302 shortened to fit in a ranger, would i need to change the tranny and t case to swap it in?
There is no bell housing to bolt an FM145 to a 302. Also, the 302 will DESTROY that transmission without even trying. The 2.9 breaks the FM145, it doesn't stand a chance against a V8.
Yes, better to use a V8 trans and transfer case.
8.8" rear axle would also be something to think about
cut n turned d44 beams an long radius arms on their way. im thinkin ill just do more work to the 2.9, a 302 swaps gonna be over $1000 plus the engine
thanks, havent seen alot of 1st gen prerunners
That does look awesome can you post up moar pics of how the bumper is attached and also are this aftermarket fender?
I have some fiberglass fenders like the ones on his truck....
3" cutout, 3" flair....
Fiberglass unlimited. They have been really decent for me. I havent beat them up in the rocks yet, but they have taken everything I have thrown at them so far.
removed inner fenders an relocated components to make room for the engine cage. ill be getting 14" king coilovers
Featured Ranger Based Vehicle
