2WD Ranger front tow hook
Featured Build Threads
4ohranger11
ASE Certified Tech
The Colony
TX - USA
Vehicle
Drive
35x12.5r15
I have a 2WD 2011 ford ranger and I want front recovery points
It does not have the cross section across the front frame rails.
Anyone come across this?
Something custom built or retrofitted to work as a recovery point on the front.
You have a few options…
The front piece could be cut out of a junkyard truck and welded into yours. That would provide a factory look.
You could make or have made something custom.
Most off-road bumpers integrate tow points.
Or the other option is a front hitch. I think most people end up buying a “universal” hitch and making it work, not sure there is anything specific for the front of a Ranger currently but it’s been awhile since I looked. The problem is they hang down below the bumper typically so a lot of people don’t like that.
I’m actually planning on building a custom hitch for my one Ranger that puts the hitch through the hole in the middle of a factory bumper. Obviously tidy appearance is part of why, but the other reasons are the truck is lowered (yes, I know, sounds weird but bear with me), able to plug my mobile mount winch in, and gives the ability to move small trailers in tight places. I did a front hitch on my F-150 years ago. Had to manouver a trailer mounted man lift in between two houses and part of a fence and having it on the back of the truck. Flipped around and “drove” it where it needed to be. Having the steering tires closer to the hitch and being able to see where you’re threading the needle is a game changer. I probably won’t be doing a lot of that sort of thing with my lowered Ranger, but I like the idea of having it because all of my trucks get worked.
Probably different by 2011, but on my 88 the front of the frame had the exact same mounting points as the rear hitch used. Had I realized beforehand I would've bought a $30 rear hitch from the junkyard for the front. Instead I got a Reese 37042.
Any pictures of that one? Or has anyone added a concealed hitch to the front of a 97 Ranger?
I’m planning on adding a hidden hitch to the front of the Road Ranger (or maybe the Missing Linc) for the same purpose. I have several trailers and I’m planning on a couple more, and a very limited place to keep them.
Don’t know of anyone who has done it and currently the plan is rattling around in my noggin and I have a couple notes on a white board of what steel I intend to use. I don’t own a 3rd gen though so I can’t speak to frame differences. My plan involved drilling a couple factory holes out in my frame and attaching there. Either stick a threaded 3/8” bar in or a thinner bar with nuts welded on inside the frame. 2”x2”x0.250” square tube for the crossbar, angle iron for where it fits the frame, and weld a receiver tube to poke through the bumper opening (4th gen bumpers have a pretty good sized opening). I’ll calibrate my design to work with a stock bumper because I’m at the stage where I like to make things repeatable if I want more. I made the opening in my custom front bumper more generous than stock to make it easier to use the tow hooks and the hitch on the green Ranger.
Featured Ranger Based Vehicle
