- Jul 24, 2023
- Charlotte, NC
- State - Country
- NC - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Automatic
- Total Lift
- Torsion Bar Max Crank (Pre-2008)
- Tire Size
- 265/75/16
- My credo
- Professional Dingus At Work
Hey all! Long time lurker, first time poster. (Yes, I’ll do an intro later.)
Background: I have a 2003 Ford Ranger Edge 4x4 with the 4.0L SOHC. It has the very beginnings of the dreaded timing chain rattle, and i am trying to preserve the engine/timing for a bit more until I am able to do the timing.
To do this, and someone else on a forum suggested this, is, before you start it, push the gas all the way down. This put the engine in flood mode, and does not fire the injectors. This allows you to crank the engine indefinitely without it starting. So you “floor it”, and crank it for 5 seconds, rest, repeat until you have oil pressure. This relives the stress (and audible rattle at startup) on the chains from the failing tensioners. And it works great, I do it at the beginning of the day when the engine is dead cold and it keeps the start up rattle away.
Anyway. Been doing this almost since I got this
tuck. Today, I go to do this, and when it is turning over it is going super super fast, far faster than normal. Enough to shake the cab even.
I was super worried, but then I went to start it once I had pressure and it started right up, as usual. Now I’m confused, as I am worried something is wrong, but it starts fine so I dunno. I have also repeated it multiple times, same result. Also, no loss of power is noticeable, but I don’t push it too much as it is because of the timing.
Would some of you wonderful people offer some advice?
