2000 Ranger XLT Radio loses reception after about 20 minutes then fades, CD Player always works
BillRod
Colorado Springs CO
Hi All
Wife's 2000 Ranger XLT, bought in 2018.
Aftermarket older Sony AM/FM/CD player.
The last year or so the radio will only last about 20 minutes then it will lose reception and fade, kinda like driving in the mountains and losing signal reception.
However this happens every time she drives it, It is a time thing not a location thing.
My F-150 has a very similar Sony so I swapped them and the issues stayed in the Ranger, it never moved to my F-150.
When the radio fades we can switch to playing CD's without issue.
The next time she gets in the radio works great but again only for about 20 minutes, as if it is a heat related issue.
Since the CD player will work regardless of anything it seems like it's maybe not the speakers.
Since it works great each time she gets in the truck it does not seem like it would be the antenna.
Anyone have any similar issues or thoughts?
Thanks in advance.
Bill
Had an similar issue in 2000 Ranger that I bought new. In 4 or 4 years the radio CD would get warm on a long trip, listening to CDs. Worked but warm and warmer. In a year or two found factory radio CD player was killing battery overnight and removed. That fixed draining the battery, so tells me it was internal to factory radio.
But there is plenty of wiring and components behind the dash that go bad. Last month this 2000 Ranger came back to me. Guages don't half work, 4wd won't engage etc. I think it is something behind the dash.
Since you said the problem stayed with the Ranger after you swapped units, this really sounds like something electrical on the Ranger is generating radio noise interference (radio static, or RFI) which is blotting out the radio's reception.
Unfortunately I can't think of anything what it might be (especially something that only comes on after 20 minutes)...
Is there anything electrical / electronic you (she) might've changed or added to the truck in the last year or so when you said this started happening? (LED lights (offroad/driving lights, headlight capsules, interior bulbs, etc.), added or changed out a stereo power amplifier? Dash-mounted GPS unit? Even a USB or phone charger?)
Maybe is there something in/on the truck you notice "turns on" about the time the reception disappears?
