2.9 L starting trouble 1986 ranger
Featured Build Threads
I sprayed gas down the intake it will hit
OK, I found the plug plugged it in. It ran for probably about 30 seconds and then cut back off. It will hit if I give it a little bit of throttle but we’re not run now.
So itll run on throttle but wont idle?
It’ll do both if you give it starter fluid but not either with out it
Ok so its a fuel issue.
Check your pressure at the rail...if that checks out the ECM isnt grounding the injectors to fire them
I have good pressure at the rail. Now it is the trouble shoot for grounding
How and were are the grounds for the injection / ecm
Featured Ranger Based Vehicle
