2.9 L starting trouble 1986 ranger
Colepitts
Forum Member
Dawsonville
GA - USA
Other
Vehicle
I’m having trouble getting my 1986 ranger to start. My current situation is new cap and rotor but no start. Before i swapped it it would sometimes start and run like a washer machine but mostly do the same as now. And before that it would sometimes start and run great sometimes it would run like crap . If it ran like crap it would just “fix” its self again siting for a day and run normally again. I have the cap and wires ran 1 4 2 5 3 6 so they should be all in the right spot. Not sure if I need to replace the whole distributor? The coil is new new ,spark plugs and new wires. Any suggestions are appreciated thanks for reading my post
Sincerely Cole
Have you determined if you’re getting spark to all cylinders when it’s acting up?
Sounds like you have a faulty ground or a broken wire to me. I would start by ohm-ing the ground wire for the TFI, testing the 12v source snd then as a last case scenario replacing the TFI module.
I would be looking at the fueling system. I had an 86 that sometimes would run really rich then magically clear itself up. Never did figure it out. But mine was definitely fueling system. You know it's getting spark and correctly because it does run correctly, even if sporadic...
Tho a bad connection might cause sporadic problems.
This sounds like a fuel issue.
First thing....check the fuel pressure.
The 2.9 is batch fire, meaning it fires 3 injectors at once. I would pull the spark plugs and see if they are all the same color, any that are much darker or lighter then the others indicate the likely problem cylinders.
Start there and report back
When it was running I could pull 3 spark plugs and it would ran the same . Just pulled the plugs the ones that were “dead” look almost clean but the others are black and smell like gas
Are the 3 clean and 3 dirty on opposite sides of the engine? As in one bank is fouled...the other clean?
If so...coupled with the problem only happening sometimes...i would be looking at the ECM
Or a broken wire on that bank.
Piston 1 2 and 4 are the clean ones and it’s happening all the time at the moment I replaced the whole distributor and it start right run just runs like crap like it did before.
When I mess with the wires when it’s off it’s makes a “spark” nose and a hear a relay click so is it possible it somehow has something to do with the wires?
Then when I unplug the “clicking relay it does not get any spark? Could it have something to do with the wires from the relay to the tfi module
If I turn the distributor to where the tfi plug is close to the valve cover and or the body of the truck it will 100% of the time make a spark sound an click the corresponding relay
The wiring h harness is kinda “FKED” on the other side of the truck but the tfi wires hard kinda stripped as well but I have them taped up rn
Turns out a TFI wire had completely snapped, and I believe that was causing the misfire
I ended up pulling the wire harness altogether. Okay fixed the wiring, harness, soldered, and did everything correctly. Now I have installed it and it will crank the acts like it has no gas while the fuel pumps are running and has pressure in the rail.
Then the injectors arent getting the signal to fire
