- Jan 29, 2026
- Dawsonville
- State - Country
- GA - USA
- Other
- Ranger
- Vehicle
- Ford Ranger
- 2.9 V6
I sprayed gas down the intake it will hit
Where would the control for this be? / plug or wiresThen the injectors arent getting the signal to fire
So itll run on throttle but wont idle?OK, I found the plug plugged it in. It ran for probably about 30 seconds and then cut back off. It will hit if I give it a little bit of throttle but we’re not run now.
Ok so its a fuel issue.It’ll do both if you give it starter fluid but not either with out it
Pressure is 39 psiOk so its a fuel issue.
Check your pressure at the rail...if that checks out the ECM isnt grounding the injectors to fire them
Then its the wiring between the injectors and ecm or the ecmPressure is 39 psi
