#1 is the grey plug c102. It has a brown/pink wire that is hot in start.
#2 is the round plug c107 you said you broke. It has a white with blue dots wire that is hot in run.
These two wires are tied together at butt splice A. This is the main power feeding the ignition system. On the other side of butt splice A, power splits and feeds the coil + wires and the ignition module + wire. The wires to my coil are red and green because I replaced my coil plug with a aftemarket replacement, my original fell apart. If you have original coil wires, they will be white with blue dots and darkgreen/yellow dot wires.
#3 is the loom containing 3 wires that goes to the duraspark distributor. Two of them are the signal wires and the other one is a ground wire.
C is a wire nut with all the ground wires in it.
duraspark to hei wiring
