2.3L ('83-'97) 1st Gen 2.3L Cold Air Intake Possible?
Featured Build Threads
Cape May Courthouse
NJ - USA
Other
‘94 Ford Bronco
Vehicle
Drive
2.3L
I’ve searched and found nothing on 1st Gen models and think I am figuring out the answer myself but wanted to ask the forum in case anyone has any info. I am in the process of trying to install a custom CAÍ onto my ‘87 2WD but there are a lot of lines coming in and out of the stock air box. Most importantly the IAC Valve is mounted directly to the stock air box with a separate hose to the throttle body. It seems all future years have the IAC directly mounted to the throttle body or very near it. For this reason it seems it would be very complicated to install a CAÍ…
Maybe you mount the stock box in a lower location and only leave the IAC on it and the smaller air line and then use the CAÍ for the main intake but that seems kinda dumb and problematic.
My main reason for a CAÍ is to clean up the engine bay. I am already relocating the battery to the back of the truck so that is not an issue. Any improvement in sound is welcome but I’m not expecting HP gains. Just trying to clarify my intentions….
Mount it to the intake you're making? IDK what it looks like on the original 2.3.
This is my 85 probably looks exactly like this.
  • 1st Gen 2.3L Cold Air Intake Possible?
Hmm. Later intake?
Your current intake system IS a cold air intake. It brings in cold air from outside the engine bay.
The easiest way around having the IAC mounted to the filter box would be to use a filter box and intake/throttle body from a later model truck.
An entire later intake/throttle body is interesting. Never thought about that and no idea if it would fit but will look into.
I totally get that the stock setup is a CAI and it’s quite well done TBH. I just want to clean the engine bay up and get the filter where the battery is now. That will really open up the engine bay and streamline it.
I’m honestly thinking about just using the stock intake filter box and modifying the large pipe only to get it where the battery is now. That would be simple and a compromise to get where I want without risking any performance or reliability issues. Modifying the flex piping bringing cold air in from the grille should be easy enough after relocating the filter box…
Featured Ranger Based Vehicle
