1994 Ford Explorer Clutch - Help Needed
Featured Build Threads
TrapperMan2024
Forum Member
Minnesota
Hey All-
I swapped in a 1994 4.0 in my 1986 Ranger, along with the manual tranny and t-case...
I installed a new slave cylinder and master cylinder. I have bench bled (ford specific) and used the mity vac bleeder to remove all the air and play in the clutch master cylinder. And when I hooked it up and bled the remaining slave cylinder, I still cant get the tranny into gear when I push the clutch in. What am I missing?
I've ran quarts, yes, quarts of fluid through the system witch no change. There is a viewing window on the drivers side of the tranny and when I my son pushes on the clutch, it appears to move the clutch about an 1/8" of an inch. How much is it supposed to move? What am I doing wrong?
new install that has never ran?
with the engine off & foot off the clutch can you go thru the gears? that checks the tranny.
You should get 5/8” to 3/4” of travel. Can you bench bleed the clutch master cylinder? There are good utube videos.
I had that problem recently. The firewall had a tear and the master cylinder was pushing out when I pushed the pedal. At least something you can look for...
Event Coverage
Featured Ranger Based Vehicle
