1991 2.3L - Failed emissions test terribly.
ggauld
10+ Year Member
Hey everyone,
I picked up a 1991 Ranger with the 2.3L I4 a while back. Shortly after getting it home we realized it had a blown head gasket. We pulled the engine apart and replaced the head gasket along with a whole assortment of other components while we were at it. When we were finally confident with how it was running again, we took it for its e-test and were shocked by the results. NOx levels passed with flying colours...HC failed at high idle with 148/98 and passed at low idle with 180/200. But CO levels failed miserably on both trials. It read 7.86/0.55 at high idle and 7.31/1 at low idle.
Does anyone have any idea what could possibly cause the CO levels to be so high?? The truck runs like a dream, starts right up and no knocks, pings, etc. It has new plugs, wires, ignition coils, clean air/fuel filters, and O2 sensor. The only clue that something is off is that the engine seems to bog down for a split second if you really (and I mean REALLY) step on the gas quickly.
The check engine light does come on once in a while, so when I get the time I plan to test for OBD-I codes...But does anyone have any ideas to point me in a possible direction? I also checked the resistance of my injectors with a multimeter and they were all slightly high...around 17 ohms where my chilton manual says to be looking for 12-16. I don't feel like that could account for SUCH a high CO reading though. Vacuum, compression, and fuel pressure tests all also gave values within spec.
I don't mind spending the time/money to swap out some more sensors or something, but my main concern at this point as that with levels that high, it's not going to improve enough...has anyone ever heard of having values that high? If I take it to get tested again I would at least like it to have a chance...would I be further ahead to just cut my losses?
Sorry for the long post! Just trying to cover all my bases. Thanks in advance.
Cheers.
sounds like you tested it cold. Drive the truck enough so it warms up to operating temperature and learns how it needs to adjust the fueling, and before the test drive the truck hard and go in at a time when you won't be sitting in line waiting, what you want is the catalytic converter to be nice and warm so it converts the CO and HC.
Check the codes first, there isn't a lot going on on that engine but one thing you might want to do is get some CRC mass airflow sensor cleaner and clean the MAF.
Yep, check the codes...high CO is a fuel issue...too much fuel or possible engine damage...could also be PCV or even dirty oil...
I found this link on google...it might give you an idea where to look if the codes don't point it out directly...
http://www.aircare.ca/repinfo-ere-causes-co.php
It can also mean the cat wasn't active yet, like it was given enough time to cool off from idling for a while, or was just started... I wouldn't over think it until the codes were checked though, in Oregon you can take the vehicle through DEQ as many times as it takes and only pay for the one that works, if wherever you are at is the same way I say check the codes and take care of any issues then try again with a warm catalytic converter. For the record there is a fine balance where there is very low emissions, if it's running too lean you'll get NOx but low CO and HC, rich and you'll get high CO and HC but low NOx. There's other factors that go into play but that's the basics at no load idle...
