1988 b2 98 explorer 4.0 swap.
Featured Build Threads
ranger480
10+ Year Member
Milton, WV
Hey everybody. Just a question about anti theft.
I have a 1998 ford explorer for parts. It came from a friend that owns a tow company. It was a impounded vehicle with a busted ignition. I wanted to convert a 88 b2 with the drive train from this explorer. The explorer won't run because the anti theft system and junk ignition.
Anyone have a idea to get around this.
I found a complete explorer colum with keys thinking about swapping.
I would like to use everything from the explorer dash and all kind of like a restomod.
I understand the project just looking for answers on anti theft
Thanks
Anti-theft runs out of the ECU, there's no way to "bypass" it. You might be able to get an ECU from a non-theft model (earlier) and get it to run. I've done it once on a ranger but it was years ago. Good luck!
It can be done, the PATS can be removed along with all the EVAP, down stream O2 sensors, and tranny if you so desire. I installed a complete 2000 Explorer 5.0 using the Explorer setup in my 76 Bronco. The only thing you really need is the engine, engine harness, the engine sensors, front O2's and I like to run the in tank fuel pump to keep it all OEM. This will make it better if this model is returnless fuel system, I'm not sure on the 4.0's if/when they went to a returnless system, it makes it easier to find parts for it but that is up to you. You will need to find someone who can remove these from the PCM. Here is the guy to contact to do just that, he will hook you up and is very good to work with, he goes by "EFI Guy" on Classic Bronco. I have his # if you want to PM me
http://classicbroncos.com/forums/showthread.php?t=224697
Event Coverage
Featured Ranger Based Vehicle
