1350/1354 dual case help
Levi.jones19
10+ Year Member
I have two 1350bw tcases. I want to do double cases but need a solid answer first. Every dual case setup ive seen is 1350/1354. Do i need to get a 1354 or can i run the two 1350s? Whats the difference and what dis the 1354s come in. Help apreciated
i think it is some thing to do with the fixed front yoke on the 1354???
Correct, the 1354 is more desirable because of the fixed yoke front output (found in 1990½-1997 Rangers, 1991-1994 Explorers).
There is nothing to stop you from doing dual 1350s though. Other than the yoke, the two cases are basically the same.
I like the 1350s better. Just makes dropping the front shaft quicker.
Yep, but not something you intentionally want to do when flexing...
SVT
