- Apr 13, 2009
- '06, '11
- 3.0 V6
- Automatic
One of the things that helps with welding is lots of light on the area. You have to be able to see the weld puddle. Put some 500 watt halogens on the area, or the led equivalent. Also don't have the mask turned too dark. The UV rays are blocked regardless of where you have the setting at. And finally, make sure you can see the melted metal ( the puddle) moving along where you want the weld to go. Make sure both edges are melting into the puddle. It's fairly easy when you weld on a flat horizontal surface, but when you do verticle it's harder.
As a rule, vertical up is stronger but harder. Verticle down looks better but is weaker.
And a grinder helps hide all manner of sins... Lol
