DRanger024
Permanent Noob
⭐Supporting Member
💻 TRS Socials
Ham Radio Operator
- Aug 16, 2007
- Dale
- State - Country
- WI - USA
- Other
- 2016 Lincoln Navigator
- Vehicle
- Ford Ranger
- 4.0 V6
- Manual
I didn’t actually cut my crossmember clean in half. I slit it more towards the passenger side bend I think because it was the flattest there. When I got it up in between the frame rails, I bolted it together finger tight then used the floor jack and vise grips to line it up so the kerf of the cut was even. Tack the outer edges of the cross member to hold the gap and weld whichever direction you are comfortable with. I went vertical up for the penetration. For plating, just weld some 1/8” thick straps along the bottom flanges of the crossmember about 4” long. That’s all I’ve done and it’s held up perfectly. I actually jumped the truck before I plated the crossmember with zero issues.
